Access SCADA-web configurator
Forum Home Forums Installation Issues SCADA-Web Installation Access SCADA-web configurator
  • #1699
    Avatarsaman82
    Hi, How can I access SCADA-web configurator? I cannot find it anywhere.
    #1700
    MikhailMikhail
    It became a part of the web application. Login the Webstation app as administrator, go to Main Menu > Configuration > Web application.
    #1701
    AvatarSergeyLeb
    Sorry, but I can’t find how I can add my views. What the Internet browser could be used?
    #1702
    AvatarSergeyLeb
    Sorry for the disturbance. I found how it could be made.
    #1741
    Avatartom040264
    Hello Mikhail,
    I did login the Webstation app as administrator, went to Main Menu > Configuration > Web application, but I was able to see only the status of different plugins (Active) and had the possibility to deactivate them.
    How can I start any of these plugins, e.g. Web Configurator?
    Thank you in advance
    T.
    #1742
    MikhailMikhail
    The active plugins are already started. If you deactivate them, you will see that some menu items or views disappear.
    For example, if the menu item “Main Menu > Configuration > Web application” is visible, it means that Config plugin works.
    #1743
    Avatartom040264
    First of all thank you for the quick response. This is clear, but how can I get to the Web configuration mask/form like in the User Manual described? I have found no way there.
    T.
    #1744
    MikhailMikhail
    Oh, the manual a bit outdated. The windows application SCADA-Web Configurator was transformed to a web page.
    #1748
    Avatartom040264
    Hello Sergey,
    Can you help me plese? I have the same problem and cann’t finde the way to display any charts or pictures.
    BR
    T.
    #1749
    MikhailMikhail
    Create a new topic and provide the details of the issue.
    #1765
    AvatarSergeyLeb
    Hi, You should go to Interface in the SCADA Administrator and add there your items. The table or pictures must be in directory X:\SCADA\Interface\your system.
