trauden
Participanttrauden
ParticipantOk thanks Mikhail.
trauden
ParticipantHi Mikhail,
I use the default chart.trauden
Participanthi,
I’ve just updated the Momo.
However, the problem is solved
This reply was modified 7 years, 4 months ago by
trauden.
trauden
In my rasp pi, Mono’s version is 4.6.2.
Mono must update to 5.20.1.trauden
Yes I use Apache/
I followed the installation steps as listed in the instruction.
However, one step, I was confused. Maybe I did wrong.
5. Add the Mono repository to your system.
Open http://www.mono-project.com/download/#download-lin and follow the instructions of paragraph 1.Example for Debian:
sudo apt-key adv –keyserver hkp://keyserver.ubuntu.com:80 –recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
echo “deb http://download.mono-project.com/repo/debian stretch main” | sudo tee /etc/apt/sources.list.d/mono-official.list
sudo apt-get updatethe result:
pi@raspberrypi:~ $ sudo apt-key adv –keyserver hkp://keyserver.ubuntu.com:80 –recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
Executing: /tmp/apt-key-gpghome.60DVyivYJz/gpg.1.sh –keyserver hkp://keyserver.ubuntu.com:80 –recv-keys 3FA7E0328081BFF6A14DA29AA6A19B38D3D831EF
gpg: failed to start the dirmngr ‘/usr/bin/dirmngr’: Khng c tp tin hoc th mc nh vy
gpg: connecting dirmngr at ‘/tmp/apt-key-gpghome.60DVyivYJz/S.dirmngr’ failed: Khng c tp tin hoc th mc nh vy
gpg: keyserver receive failed: Khng c dirmngr
pi@raspberrypi:~ $ echo “deb http://download.mono-project.com/repo/debian stretch main” | sudo tee /etc/apt/sources.list.d/mono-official.list
pi@raspberrypi:~ $ sudo apt-get update
Ly:1 http://download.mono-project.com/repo/debian stretch InRelease [5.878 B]
Ly:2 http://archive.raspberrypi.org/debian stretch InRelease [25,4 kB]
Tm thy:3 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Bq:1 http://download.mono-project.com/repo/debian stretch InRelease
Ly:4 https://download.mono-project.com/repo/ubuntu stable-bionic InRelease [5.143 B]
Bq:4 https://download.mono-project.com/repo/ubuntu stable-bionic InRelease
ly v 36,4 kB mt 2 giy (14,0 kB/g).
ang c cc danh sch gi… Xong
W: Li GPG: http://download.mono-project.com/repo/debian stretch InRelease: Khng th kim chng nhng ch k theo y, v kha cng khng sn c: NO_PUBKEY A6A19B38D3D831EF
W: The repository ‘http://download.mono-project.com/repo/debian stretch InRelease’ is not signed.
N: Data from such a repository can’t be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: Li GPG: https://download.mono-project.com/repo/ubuntu stable-bionic InRelease: Khng th kim chng nhng ch k theo y, v kha cng khng sn c: NO_PUBKEY A6A19B38D3D831EF
W: The repository ‘https://download.mono-project.com/repo/ubuntu stable-bionic InRelease’ is not signed.
pi@raspberrypi:~ $Thanks for rapid answer.
trauden
ParticipantThank you a lot Mikhail.
It works now.trauden
ParticipantHi, Mikhail,
Here is the photo.
https://drive.google.com/file/d/1ZdlFSsyXAknoVryPJPpzgL8p_EbNyAY_/view?usp=sharing
I’ve done as the instruction.trauden
the display on the installed plugin’s web is oke.
I post pictures, Please help me.
https://drive.google.com/drive/folders/1cblLH3VuFdWw4yBWT7p7vT-kGULoJ84X?usp=sharing
BRstrauden
ParticipantOke Thank Mikhail.
trauden
Participanttrauden
Thank you for the quick answer.
I Installed Rapidscada v5.6 and using the old configuration. Firstly, It worked correctly. A then the schemes unsuccessfully load. I think the table is oke.trauden
Rapid SCADA can upload data to a database in clound bys this similar way.
Raspberry->NodeRed->Ubidots clound ?
http://help.ubidots.com/developer-guides/connect-node-red-with-ubidotstrauden
ParticipantThansk you Mikhail for the fast response.
I am finding out.trauden
In Adminitrator for input channel there are 4 parameters for setting alarm threshold: Lower alarm limit; lower limit upper limit and upper alarm limit. I mean, how to adjust value of these parameters via the Web site (web interface). -
