wanbinqs@gmail.com
  • in reply to: Is there a better way to batch modify channel attributes? #17217
    wanbinqs@gmail.com
    How to export CSV files individually for different channels?
    in reply to: opc DA disconnection and reconnection issue #17204
    wanbinqs@gmail.com
    Thank you for your reply. My problem has been solved. I changed the computer and reinstalled the software and related OPC core, and the communication was restored.
    in reply to: opc DA disconnection and reconnection issue #17185
    wanbinqs@gmail.com
    Can this OPC disconnection problem caused by an unexpected network outage be resolved? Why hasn’t the data been restored after the network cable was restored?
    in reply to: opc DA disconnection and reconnection issue #17183
    wanbinqs@gmail.com
    I searched for relevant information to find out whether this situation occurs because the COM Session is recycled by the system?
    in reply to: opc DA disconnection and reconnection issue #17182
    wanbinqs@gmail.com
    It started around this time yesterday. I initially thought the network cable that transmitted the OPC was disconnected and needed to be refreshed and uploaded again. This is the log of the webstation after the re-upload. Now I can still connect to the OPC and see the items, but the data is not refreshed.
    in reply to: opc DA disconnection and reconnection issue #17181
    wanbinqs@gmail.com
    2025-10-16 10:23:33 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Webstation 6.2.2.0 started
    2025-10-16 10:23:33 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Storage FileStorage 6.4.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\FileStorage.dll
    2025-10-16 10:23:33 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Plugin PlgChart 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgChart.dll
    2025-10-16 10:23:33 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Plugin PlgMain 6.1.1.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMain.dll
    2025-10-16 10:23:33 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Plugin PlgMimic 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMimic.dll
    2025-10-16 10:23:34 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Plugin PlgMimicEditor 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMimicEditor.dll
    2025-10-16 10:23:34 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Plugin PlgMimBasicComp 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMimBasicComp.dll
    2025-10-16 10:23:34 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Plugin PlgScheme 6.1.1.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgScheme.dll
    2025-10-16 10:23:34 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Plugin PlgSchBasicComp 6.1.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgSchBasicComp.dll
    2025-10-16 10:23:34 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Plugin PlgStore 6.1.0.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgStore.dll
    2025-10-16 10:23:34 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Plugin PlgWebPage 6.1.1.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgWebPage.dll
    2025-10-16 10:23:34 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Plugin PlgMimic: Add components from the PlgMimBasicComp plugin
    2025-10-16 10:23:34 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
    2025-10-16 10:23:34 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
    2025-10-16 10:23:34 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Receive the configuration database
    2025-10-16 10:23:37 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] The configuration database has been received successfully
    2025-10-16 10:23:37 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][INF] The application is ready for operating
    2025-10-16 10:27:35 [DESKTOP-J9R71LQ][DESKTOP-J9R71LQ$][ACT] Webstation is stopped
    • This reply was modified 1 year ago by Mikhail.
    in reply to: opc DA disconnection and reconnection issue #17180
    wanbinqs@gmail.com
    Is it the log file of the server? Or the log file of webstation?
