Thank you for your positive feedback.
I strongly recommend to upgrade to Rapid SCADA 6. We significantly improved Modbus Slave driver to make it easier to configure. Is it possible for you to upgrade and then discuss the up to date version?-
This reply was modified 2 years, 1 month ago by
Server 5 and Server 6 must use different TCP ports to be able to work in parallel. Client applications should connect to a proper TCP port.
does updating from 6.1 to 6.3 require data imigration ?
Projects are compatible. Project migration is not needed.
How to pack souce rapidscada code project to installation .exe file setup ?
Build the source code according to the instructions. Then copy the files from your build output to the necessary folders.
MikhailModerator
MikhailModeratorLikely, it should be connected to the Linux server where the Communicator service is working.
According to the logs, Rapid SCADA 6 works well. But you open Rapid SCADA 5.
Try http://localhost:10008 (by default)
MikhailModeratorYou can set Modbus ID in the device options (Communicator app). Unit ID = 1 is the most popular. Could you provide screenshots of your settings?
August 19, 2024 at 8:14 am in reply to: Modbus TCP No sending command for write new value to slave device #15159
Could you clarify your question by providing screenshots?August 19, 2024 at 8:05 am in reply to: RapidGate from Rapid SCADA 6.3.0 to Rapid SCADA 6.2.1? #15157
Probably, you can. The project format and communication protocol are compatible.
MikhailModeratorWe upload the latest version of the applications and modules on the website. If you need a certain version of a module, use Module Store.
MikhailModeratorI noticed the ModAutoControl config file is empty, could this be causing the error?
Yes, this is the cause of the error. Make sure that the module version is compatible with the Rapid SCADA version. I recommend to update the both by downloading them from our website.
You need to restore the module configuration from a backup copy. A file copy also can be found at SCADA\ScadaServer\Config (working copy of the configuration)
To use REST API you should connect to the web application. The Server application supports custom TCP-based protocol. See this link for more details.
MikhailModeratorIt depends on the connection interface and communication protocol.
There are no images at the above link. Could you fix it?
