Viewing 15 posts - 6,181 through 6,195 (of 6,387 total)
  • in reply to: WCF Service error #602
    Is there any additional information in the log files in the folder C:\SCADA\ScadaWeb\log ?
    in reply to: Call number length limitation #600
    The complexity of increasing the field length is that the database structure becomes incompatible with the previous version. I’d prefer to include a fix in the next major version of Rapid SCADA, if a workaround exists.
    in reply to: Call number length limitation #599
    Hi Bret,
    The field length issue shall be fixed. But it tooks a time.
    Are all of your devices have the same port?
    In this case you can set “Remote TCP Port” of communication channel properties in SCADA-Communicator and omit port in SCADA-Administrator.
    Every input channel has a Signal. Signal is an ID of a tag in SCADA-Communicator.
    in reply to: Change background color of dynamic text box #597
    Hi Dejan,
    Yes, use “Status” color. The color depends on input channel status that can be calculated with formula.
    in reply to: Dynamically display text in a text field #595
    It’s easy. Add your messages to Units table like “Alarm states 1” record. Then select created unit for an input channel with Discrete channel type and Text format.
    1st message is 0.0 (value)
    2nd message is 1.0
    etc.
    in reply to: User Logo #593
    SCADA-Web:
    Go to C:\SCADA\ScadaWeb\images
    Then just overwrite the images.
    Also you can change css styles in *.css but is is not recommended because you should do the same task when a new version released.
    Other applications:
    Add the files in the application directory (for example, C:\SCADA\ScadaServer):
    About.txt
    The content of About.txt:
    http://rapidscada.org
    232 174 95 23
    There the numbers are X, Y, width and height of the link.
    in reply to: Current Data #592
    Switch to Modules page in SCADA-Server and add ModDBExport.dll
    SQL examples are located in Doc\dbexport_en.pdf
    In case of questions about DB Export Module, post them in a separate topic.
    in reply to: User Logo #589
    Would you like to insert the logo into the web application only or into all the applications of Rapid SCADA?
    in reply to: Current Data #588
    Usually it is needed to export hourly or minute archives to Excel. To export current data you could set up export to any database and use the 3rd party tools to export to Excel. Of course you can develop or purchase the custom report.
    in reply to: Communicating Multiple Devices #585
    a) Yes.
    b) Yes, if you use another port of converter.
    No, if you use the same port.
    c) Yes.
    in reply to: Server Connection #582
    Is there error cause in
    C:\SCADA\ScadaWeb\log\ScadaWeb.log
    C:\SCADA\ScadaServer\Log\ScadaServerSvc.log ?
    in reply to: Communication #579
    OK, create a separate topic please.
    in reply to: Communication #577
    EB 76 is the checksum
    43 D0 FE 05 is the value 417.984528
    You should set the correct bytes order in Device Template Editor.
    Try the order 2301.
    Please notify me about the result.
    in reply to: Communication #575
    I would like to see the log.
    in reply to: Communication #572
    Can you post here a part of communication line log? And the expected value.
    If it is possible also provide MODSCAN log for comparison.
