Viewing 15 posts - 5,956 through 5,970 (of 6,387 total)
  • in reply to: BACnet Support #1144
    Instead of sponsor it could be a guy, who develops a BACnet driver for Rapid SCADA ))
    What is your Windows version?
    Please open http://localhost/scada/scheme/ScadaSchemeSvc.svc and post a screenshot.
    in reply to: BACnet Support #1140
    There is a topic about BACnet: http://forum.rapidscada.org/?topic=bacnet
    In short, it would be great to implement BACnet, but for the current moment there are several the most priority tasks. BACnet can be included in the nearest plan if we find a sponsor for this feature.
    in reply to: No Data passthrough to webpage #1135
    OK 🙂
    in reply to: Calculated Real working unreliable #1128
    You have to use Caclculated channel type for channels 2&3 and define formulas for them.
    in reply to: Calculated Real working unreliable #1126
    Is an alarm value for Channel 1 is generated by a device? In this case you can calculate values of other channels using formulas which depends on Channel 1 as you wrote Val(n). May be I didn’t catch your question.
    in reply to: Changing Table Colors, and event line color #1124
    It’s weird.
    I usually do the following:
    1. Copy *.css to C:\SCADA\ScadaWeb\css overwriting the existing file.
    2. Open the web application in a browser and press Ctrl + F5
    If you think that a file is not updated, delete it first, press Ctrl+F5 to make sure that styles disappear, then copy the new file and press Ctrl+F5 again.
    in reply to: DLMS / COSEM #1121
    Hi Fahrur,
    There is no such protocol in the nearest plan. There are 2 ways:
    1. Using OPC server, for example, http://www.matrikonopc.com/opc-drivers/opc-dlms/base-driver-details.aspx
    Pros:
    – Faster to start.
    Cons:
    – You should pay for each license of the OPC server.
    2. Purchase development of a native driver for Rapid SCADA.
    Pros:
    – More effective and stable in work.
    – You should pay once.
    Cons:
    – Take more time to develop.
    in reply to: Complete Formulas Functions and Variables #1118
    The manual contains the hardcoded functions. Whereas, GetBit is defined in the configuration database in Formulas table.
    You definitely right – the documentation should be updated and improved. In the plans there is changing its format to HTML to make updating easier. Unfortunately, work takes more time than generating ideas )
    Thanks a lot for your vision.
    in reply to: Calculated Real working unreliable #1110
    See also:
    C# Operators
    The easiest way tor debug your formulas is creating console application using Microsoft Visual Studio Community Edition.
    in reply to: Calculated Real working unreliable #1109
    To create a new function open SCADA-Administrator -> Formulas table. It already contains a few examples.
    If you need a formula to calculate input channel value, it should be as the following:
    double MuFunc()
      return 1; // for example
    Then enter the formula in the Input channels table: MyFunc(); 1
    Where 1 is status of the input channel.
    Anyway the channel value is double. If you need string representation, use Unit table (find the example in the default configuration database).
    Also read about using formulas at Part 3. Software Configuration in http://rapidscada.org/product/documentation/
    in reply to: Rapid SCADA on Orange Pi 2 plus #1108
    Thank you for the info.
    The issue is entered in the tracker in order to be resolved in the future.
    in reply to: Communicator using 100% CPU #1107
    Solved. Will be published in the next version.
    in reply to: Calculated Real working unreliable #1102
    Radix, could you write the required formula using C++, C# or math? In this case, I can tell how to apply it to Rapid SCADA.
    in reply to: Changing Table Colors, and event line color #1098
    I you don’t find the answer with Chrome, I’ll help you, OK?
