Viewing 15 posts - 5,911 through 5,925 (of 6,387 total)
  • in reply to: Several days/channels graphs are generated slooooowly #1248
    Thanks!
    If somebody are able to compare the charting speed with other SCADA software, it would be very interesting and useful.
    in reply to: Several days/channels graphs are generated slooooowly #1244
    The issue is enqueued.
    in reply to: Firefox left w/ graphs open overtakes RAM #1243
    I’d prefer not to promise. In the summer it has to be released )
    in reply to: how they work: Events, Alarms and Limits #1242
    I agree, “events enabled” is better.
    Averaging:
    Received values are summarized within a period (minute or hour) then divided by their count and the result is stored to archive.
    Events:
    In the new web app the chart list will use the common page template, so events will be visible. Thanks, recently I thought whether it is required or not.
    in reply to: Excel Exporting #1238
    Notes about a custom solution:
    We can develop a module that will allow:
    – Choose input channels and set a period of storing for the each selected channel.
    – Store separately and fast access trends of these input channels.
    – Display charts and export data to different formats.
    in reply to: ModAutoControl not working? #1237
    PD: forum tips:
    I recommend Extended support service. It includes Redmine ticket tracker which is much more comfortable.
    in reply to: ModAutoControl not working? #1236
    Your triggers are configured as
    <ChkCnlStat>true</ChkCnlStat>
    <CnlStat>0</CnlStat>
    It means that channel status must be 0 (undefined) to fire the trigger.
    in reply to: Excel Exporting #1234
    There are 3 ways:
    1. Optimal. Export these data to DB using DB Export Module. Then use this approach to display charts.
    2. Fast to implement. Manually set storing period for minute data in C:\SCADA\ScadaServer\Config\ScadaServerSvcConfig.xml
    Cons: large data archives and slow charting
    3. Create a custom solution to fit your needs.
    in reply to: Several days/channels graphs are generated slooooowly #1233
    Thank you for the research. It would be useful to optimize the chart.
    in reply to: Several days/channels graphs are generated slooooowly #1232
    Nothing is impossible 🙂
    in reply to: Firefox left w/ graphs open overtakes RAM #1231
    No, I think it’s better to release the new web app ASAP.
    in reply to: Excel Exporting #1224
    Do you mean that you need to store data every second?
    in reply to: Microsoft SilverLight #1222
    Within a few months.
    in reply to: Microsoft SilverLight #1219
    The spring was too optimistic. The work is in progress. You can see a screenshot here. I hope the result will satisfy our users.
    in reply to: how they work: Events, Alarms and Limits #1217
    WRITE EVENTS: if false, no event for the channel will be written and shown.
    EVENT SOUND: plays beep in browser. Just try.
    EVENT ON CHANGE: on any change. Usually the option is used for discrete values.
    EVENT ON UNDEFINED: e.g. connection is lost. Event fires when the channel status is 0.
    LIMIT: I recommend trying it using SCADA-Server generator.
    Object field is optional. Device field is required if channel value is measured by a device.
    Are any events shown when in Report/List Chart view?
    Sorry, I didn’t catch the meaning.
    Have a nice weekend too 🙂
