Viewing 15 posts - 5,731 through 5,745 (of 6,387 total)
  • in reply to: Display of current data value #1654
    Good idea, thank you.
    I’ve added it to the issue list.
    If it is critical to your project, it is possible to change the Unreliable status to Undefined by a formula of input channel.
    in reply to: SendStandardCommand, SendBinaryCommand, SendRequestCommand #1651
    You can create special files. Try to stop SCADA-Server then send commands using Communicator. You can see the files in C:\SCADA\ScadaComm\Cmd
    There is an example how to do it.
    • This reply was modified 9 years, 12 months ago by Mikhail.
    in reply to: Display of current data value #1649
    If Communicator is off, the values become undefined in 5 minutes by default. You can change this time span by the parameter “Unreliable on inactivity” in SCADA-Server.
    in reply to: SendStandardCommand, SendBinaryCommand, SendRequestCommand #1648
    In this case you can use SendStandardCommand, SendBinaryCommand and SendRequestCommand methods which establish TCP connection with SCADA-Server. Why you need non-TCP way of sending commands?
    in reply to: SendStandardCommand, SendBinaryCommand, SendRequestCommand #1645
    Could you provide more details or example of the situation?
    in reply to: SendStandardCommand, SendBinaryCommand, SendRequestCommand #1643
    It is an ID of a user from the configuration database which you can see in Administrator. You can set it to 0 means undefined. User ID is just an information who send a command.
    in reply to: optimum system requirement #1641
    Probably, the first list item above is difficult to implement, because devices are installed for a long period of time. In this case you need a software simulator of devices, that can respond for requests.
    in reply to: optimum system requirement #1640
    polling frequency 30 sec to 5 mins distributed among devices
    This is not high load.
    1. After you configure Rapid SCADA, you should start the whole process and watch for CPU, RAM, HDD and network load.
    2. Test responsiveness of the web app by serfing data views. Compare first open time of a view if Communicator is running or not. First open time after restart application pool of IIS.
    3. Explore logs of the web app and SCADA-Server service (you should switch to detailed log).
    in reply to: optimum system requirement #1638
    1) Both are good choice.
    Server 2016 is not tested with Rapid SCADA, but I’m sure, it will work well. In case of any issues with it, I can help you.
    2-4) Very good.
    5) I forget to ask about communication protocols. Could you describe how devices will be connected?
    I think, from 10 to 100 parallel polling threads (communication lines) have to work.
    It would be wonderful if you share stats when you launch the system.
    I recommend Extended Support for important systems. Also recommend the new web app.
    in reply to: optimum system requirement #1636
    Rapid SCADA is tested in the lab with 10000 input channels and works well on Pentium i3 and 4GB RAM. Active communication between Server and Communicator may require more resources.
    Some additional questions:
    1. What OS is planned?
    2. What frequency of polling is really needed?
    in reply to: Adding new devises different approaches #1634
    If it already works, it will work further too.
    But there can be a mess for administrator.
    I recommend to create communication lines and assign them to devices.
    Objects are optional.
    in reply to: Integration issue #1629
    The most simple is MySQL and MS SQL 🙂
    in reply to: Integration issue #1628
    1521 is the default Oracle port. I don’t think you should explicitly specify it.
    Have you specified your connection settings in tnsnames.ora ?
    Connection tab contains settings those used by the shell to connect to SCADA-Server service. You don’t need to change them.
    in reply to: Scadabeta error #1627
    You should specify the views in the configuration database using SCADA-Administrator. See install_web_beta_en.pdf in scada_web_beta_en.zip
    in reply to: Saving data at remote location #1624
    It is technically possible, but it is not a good idea, because if network connection lost, data will not be saved. You can try UNC network path as a directory.
    Why do you need it?
