Viewing 15 posts - 5,701 through 5,715 (of 6,387 total)
  • in reply to: No way to use Chart Pro on 5.x #1718
    I think it will be done, may be within a month. We started to post news on https://www.facebook.com/RapidSCADA/ It should be easier to get notifications from there, I hope so.
    in reply to: No way to use Chart Pro on 5.x #1717
    It would be best to place label below or left to cursor
    I was planning to suggest to make label jump to left when it can’t be on the right.
    You wrote earlier 🙂
    Transparent is easy to implement. It’s possible to do the both things.
    in reply to: Administrator doesn't start #1715
    Thank you for the info. There are 2 popular versions of MSSSQL Compact: 3.5 and 4. SCADA-Administrator requires 3.5, but 4.0 is already installed. These versions are not compatible.
    Could you try the following:
    1. Download DLLs from https://github.com/RapidScada/dll/tree/master/SQLServerCE%203.5
    2. Copy them into C:\SCADA\ScadaAdmin
    3. Run ScadaAdmin.exe
    Please write about the result.
    in reply to: No way to use Chart Pro on 5.x #1714
    If make label a bit transparent, does it solve the problem?
    in reply to: Administrator doesn't start #1712
    The features in the screenshot are correct. They are needed for the web application.
    in reply to: Administrator doesn't start #1711
    Most likely, you have to install
    SSCERuntime_x86-ENU.msi and
    SSCERuntime_x64-ENU.msi
    from the installation package.
    I have checked that MSSQL Compact is installed and running on my computer.
    How you did it?
    May be another version of SQL Server is running.
    in reply to: No way to use Chart Pro on 5.x #1707
    Thanks for the tips.
    You can move a mouse up or down to make chart visible. May be I misunderstood the situation, it’s better to view a screenshot.
    List of the channels is needed for printing at least. It’s a good idea to group channels into columns to save space.
    in reply to: No way to use Chart Pro on 5.x #1705
    Do not disable Chart plugin. It is a parent for Chart Pro. Enable it back.
    in reply to: No way to use Chart Pro on 5.x #1704
    A bit. The installation manual was updated today.
    You should go to Main Menu > Web application, scroll down and choose Chart Pro. Then save changes
    in reply to: Access SCADA-web configurator #1700
    It became a part of the web application. Login the Webstation app as administrator, go to Main Menu > Configuration > Web application.
    in reply to: Using variables on SCADA-Scheme Editor #1696
    Hi Jesus,
    Hyperlinks are important, and they would be surely added to the Schemes. For now I can’t tell the exact date when it is ready.
    P.S. Save our Facebook page https://www.facebook.com/RapidSCADA/ to read latest news related to Rapid SCADA.
    in reply to: Channel value addition #1694
    The above formulas allow to reset (set to 0) a cumulative value of input channel. You should multiply the formula by a value you need to reset.
    in reply to: Users, Roles, Rights are not working right. #1689
    Well, I guessed.
    The minimum ID of your custom role must be 11 or more.
    IDs from 0 to 10 are reserved.
    • This reply was modified 9 years, 11 months ago by Mikhail.
    in reply to: Users, Roles, Rights are not working right. #1688
    In the last screenshot the role is Disabled. But in Users table the user Test has TestRole. Are all of these happen at the same moment?
    in reply to: New Web App Idea? #1686
    You should be careful, because if user has rights to all views, he can view events, get charts and reports for all the data, event if some views are not shown in the tree.
