Viewing 15 posts - 5,686 through 5,700 (of 6,387 total)
  • in reply to: New database #1756
    Which additional modules should I by and how can I display self made charts and displays.
    This is the standard functionality which doesn’t require commercial modules.
    I recommend Chart Pro Plugin for advanced charting. It is optional.
    in reply to: New database #1755
    2. Create a view using Table Editor or Scheme Editor. Save it into C:\SCADA\Interface
    Then define a view in the configuration database in the Interface table using SCADA-Administrator. Use the default views as an example.
    In case of follow up question be free to ask.
    in reply to: New database #1754
    1. To delete the default data, start from the Rights table and go to top to the Object table. Click the Clear table button to delete all the rows of the table.
    Do not delete roles with IDs from 1 to 4.
    Do not delete users with IDs from 1 to 3.
    Do not delete data from the dictionary tables.
    • This reply was modified 9 years, 10 months ago by Mikhail.
    in reply to: Access SCADA-web configurator #1749
    Create a new topic and provide the details of the issue.
    in reply to: Diagramms #1747
    For now, levels can be displayed by a dynamic image component. You should create a set of images, for example for 0, 10%, 20%…100% and switch them according to an input channel value. See uKon project here.
    In the future we are planning to develop a control which will display such level.
    in reply to: Access SCADA-web configurator #1744
    Oh, the manual a bit outdated. The windows application SCADA-Web Configurator was transformed to a web page.
    in reply to: Access SCADA-web configurator #1742
    The active plugins are already started. If you deactivate them, you will see that some menu items or views disappear.
    For example, if the menu item “Main Menu > Configuration > Web application” is visible, it means that Config plugin works.
    in reply to: Diagramms #1739
    Could you provide screenshots or examples?
    • This reply was modified 9 years, 11 months ago by Mikhail.
    in reply to: String for Dynamic Text #1735
    Do you mean “not supported”?
    Definitely. Excuse me please.
    If text messages have predefined text, it’s simple.
    If string should be constructed by a formula, development is required. The future schemes will support components written in JavaScript. Such components make schemes very flexible.
    in reply to: Changing text color #1734
    Interesting 🙂
    in reply to: Leading zeros #1733
    I see…
    I can suggest a hack: put a static text with 0 below the dynamic text. You should use a font with the same width of symbols, auto size and right align for dynamic text.
    Most likely, the formatting will be implemented in the next major update.
    in reply to: Changing text color #1729
    By default, statuses of input channels are set automatically. Also you can set them by formulas.
    in reply to: Changing text color #1728
    There is a special color Status. You can find it in the color dropdown list (in the element properties tool window).
    You may add new statuses in Event Types table using Administrator app and specify the colors you need.
    I think we will add new feature to set colors dynamically because the existing approach is not comfortable in case of many colors.
    in reply to: String for Dynamic Text #1727
    Such case is now supported.
    For now, to display time you should create 3 input channels of Calculated Real type for hours, minutes and seconds. Then add 3 dynamic text elements to the scheme.
    The channel formula example: DateTime.Now.Hour
    In the next version it is planned to add new formatting for input channels, so it will be enough only 1 channel for this purpose.
    Note: You can also display strings from a predefined enumeration. For example, On – Off, etc.
    in reply to: Administrator doesn't start #1721
    Thank you for the info. It may help to other users.
