WCF Service Error (HttpWebRequest_WebException_RemoteServer)
Forum Home › Forums › Installation Issues › SCADA-Web Installation › WCF Service Error (HttpWebRequest_WebException_RemoteServer)
  • #1141
    Savan Tripathi
    Dear Mikhail,
    Currently I am trying to map data of modbus device with schema by taking existing server schema and made duplicate schema and save as new name. I have put input channel value in schema editor and save in and put schema in view.
    Now i am login to scada account and clicking on schema it is showing me WCF service error. I had googled it and also go through your forum and try to made changes as per described in forum but still facing the same problem.
    I dont know how to install a latest WCF version. i had checked IIS manager Configuration and all services are currently activated.
    please give me some suggestion regarding it.
    • This topic was modified 10 years, 5 months ago by Mikhail.
    #1142
    What is your Windows version?
    Please open http://localhost/scada/scheme/ScadaSchemeSvc.svc and post a screenshot.
    #1146
    Savan Tripathi
    I am using windows 2008 server
    By putting your URL in browser there is blank page with the error ::::
    Application error: The HttpsGetEnabled property of ServiceMetadataBehavior is set to true and the HttpsGetUrl property is a relative address, but there is no https base address. Either supply an https base address or set HttpsGetUrl to an absolute address.
    #1149
    Try the following:
    0. Make a backup of C:\SCADA\ScadaWeb\Web.config
    1. Open C:\SCADA\ScadaWeb\Web.config
    2. Find the line
    3. Delete httpsGetEnabled=”true”
    The line should be
    Open http://localhost/scada/scheme/ScadaSchemeSvc.svc again.
    #1152
    Savan Tripathi
    Thank u so much mikhail, You are genious. now i am able to see the schema..
    #1155
    To be honest, thanks to the project community. Many users – many issues – many ready solutions. It is the power of open source 🙂
