MikhailModeratorDAT format is used for the configuration database, measured data (snapshots) and events. These are 3 different formats with the same file extension.
The existing utility able to convert snapshots to CSV. I can share the link to it.
One good guy gianguido is now working on other types of data.
MikhailModeratorDon’t delete an image please.
MikhailModeratorThank you. I added this bug into our ticket tracker. When it is solved, I’ll write info here.
For minute data:
It summarizes the values which were received during the minute and divide the sum by the number of values.For hourly data:
The same, but values are summarized during the hour.You can calculate number of points if create a formula that increases a counter each time when it is calculated by SCADA.
MikhailModerator
MikhailModeratorUse EncodeDate(DateTime.Now)
Each group in Modbus template is one request to a device. Address of a group is included in a request.You can try different templates by yourself then decode and compare them by http://modbus.rapidscada.net/
MikhailModeratorYou have to reinstall the Webstation app. There is a mess of the old and the new files.
August 9, 2017 at 7:33 am in reply to: Schematic picture not changing according to input channel #2474
Did you press Ctrl+F5 in browser or clear browser cache after update?
What error do you get?
MikhailModeratorDo you mean to reverse the order of events?
I recommend http://www.plcsimulator.org/ simulator. It’s free.
See this video.August 7, 2017 at 5:06 pm in reply to: Schematic picture not changing according to input channel #2465
MikhailModeratorJust download Rapid SCADA from http://rapidscada.org/download-all-files/ and reinstall only the Webstation app.
MikhailModeratorSome of the projects are outdated. Skip them. See the details here https://github.com/RapidScada/scada/issues/38
Don’t try to start the project. Just click the Build Solution item in the main menu.
I recommend Visual Studio 2015 Community Edition. It is currently used for Rapid SCADA development.
MikhailModeratorIf I open a dashboard http://demo.rapidscada.net/plugins/Dashboard/Dashboard.aspx?key=allusers-DashboardDemo using Chrome on Android 5, export to PDF works.
Could you try to open and export to PDF the dashboard by this link? I’d like to realize what is the cause of the issue: an instance of Rapid SCADA, a browser or OS. -
