Schematic picture not changing according to input channel
Forum Home › Forums › Uncategorized Issues › Schematic picture not changing according to input channel
  • #2425
    manraj
    hey there!.
    I have a problem in my schematic.How it suppose to work is like this. When you insert a value less than 100 in the Modbus for the input channel of 1001 is shows a straight grey pipe.When you insert a value of 100 equal and above it should show a pipe that is leaking.But right now the dynamic picture does not change.
    I referred to this https://www.youtube.com/watch?v=A4PuxXdivEg&t=524s but I could not get the answer to my problem.
    #2428
    Please look for a version of the Webstation app and the Scheme Plugin. The actual Webstation version is 5.0.2.1 and Scheme version is 5.1.0.2. There was an error that relates to your issue and now it is fixed.
    #2429
    If you update the web app, you have to press Ctrl+F5 or clear cache in browser to update all the scripts.
    #2463
    manraj
    My webstation is version 5.0.2.1 but my scheme version is 5.1.0.1. Where and how do i get the Scheme version updated.
    #2464
    manraj
    My scheme editor in this path C:\SCADA\ScadaSchemeEditor is version 5.1.0.2 and after restarting the server,cmmunicator and adminstration.My scheme in the http://localhost/Scada/plugins/Config/Plugins.aspx shows its version Version 5.1.0.1.I dont know whats wrong and I am having the same problem.
    #2465
    Just download Rapid SCADA from http://rapidscada.org/download-all-files/ and reinstall only the Webstation app.
    #2466
    manraj
    Hey there,
    Well i tired re-downloading the Webstation app it but it did not work.But now my scheme plugin is version Version 5.1.0.2 and my Webstation is 5.0.2.1.What should I do next?
    #2474
    Did you press Ctrl+F5 in browser or clear browser cache after update?
    What error do you get?
