Dashboard Export to PDF
Forum Home › Forums › Uncategorized Issues › Dashboard Export to PDF
  • #2448
    douglas
    Pertaining this function available in Dashboard, if using the laptop or PC to do the Export to PDF it can export successfully. However if using the tablet or smart phone browse, the Export to PDF function failed to download. Just wonder what is the problem and how to solve. Thanks in advanced for your sharing and support.
    #2454
    What tablet OS version do you use?
    #2455
    douglas
    I am using smartphone Samsung Galaxy S7 edge, SM-G935FD Android version 7.0.
    #2458
    If I open a dashboard http://demo.rapidscada.net/plugins/Dashboard/Dashboard.aspx?key=allusers-DashboardDemo using Chrome on Android 5, export to PDF works.
    Could you try to open and export to PDF the dashboard by this link? I’d like to realize what is the cause of the issue: an instance of Rapid SCADA, a browser or OS.
    #2487
    douglas
    I still encounter the same problem. Attached is the error print screen.
    #2488
    douglas
    https://drive.google.com/file/d/0B4pJ1kt8PAPbX3FTc0lmQTVUQWM/view?usp=sharing
    P/S: I failed to attach the image on earlier post.
    #2490
    Thank you. I added this bug into our ticket tracker. When it is solved, I’ll write info here.
    #2491
    Don’t delete an image please.
