MikhailModeratorThank God 🙂
OPC is unpredictable.
MikhailModeratorYou should send the commands and apply formulas for output channels that insert necessary values.
MikhailModeratorDoes https://localhost/ work?
MikhailModeratorHTTPS is more tricky. To solve this issue, a remote connection is required – this is a commercial service.
Probably, you should install or reinstall OPC Core Components.
MikhailModeratorThe Beat() function just changes a channel value every 5 seconds to be a trigger for sending commands. What value you need to insert?
You should associate HTML file extension with a modern browser.
Other option:
After starting the editor, open a browser and copy this link:
file:///C:/SCADA/ScadaSchemeEditor/Web/plugins/SchemeEditor/editor.html
MikhailModeratorAlso is it possible to display a timestamp of the when the device was connected last?
You can also implement it using formulas.
I’d like to say that the connection is not stable, it is not normal, you should find the cause and make the connection better.
MikhailModeratorInstead of defaulting to zero.
You need a formula of input channel. Try this: Stat > 0 ? Cnl : Val()
What Windows version do you use?You should open incoming connections on TCP port 80.
To check, just open http://yourIP/ from another PC. You should see IIS welcome page.
MikhailModeratorOK, be free to ask 🙂
Polling is slow, because the device doesn’t respond for “State” requests. Deactivate such requests in the template editor (keep “Temperature” active only) and compare the speed.
Scheme Editor were changed. There is the old version in the video. Please create a new topic if it doesn’t work. editor.html must be open in a web browser not Word.
The expected behavior in this case: values and statuses of tags are zero when connection is broken. Does it work as expected or not?“Unable to request because connection is not established” – probably, the device disconnects from the PC. If this is a usual LAN, you should check communication with Modbus Simulator installed on another PC. If it works normal, the problem is in the device.
MikhailModeratorHi Marko,
Nobody has purchased the development of this module yet. You can be the first 🙂 -
