I would like to know if it is possible to log an event when the value of a channel exceeds the defined values.
I can see the color of the text modifying when alarm values are reached, but no event is logged.
I must know when these spikes occur during the day.
Also, I plan to send an automated email when events like these occur, using the provided modules.
Thank you in advance.
You should run the Administrator app, open the Input channels table, choose the appropriate row of an input channel and set the following fields:
– Tick Write Events checkbox
– Define Lower alarm limit, Lower limit, Upper limit and Upper alarm limit cells
All is working fine.
I don’t know what happened, but it works now. Previously when I ticked Write Events checkbox it didn’t write the events. Now, it is working.
Now I have another problem with the WebStation, but I replied to a thread that was already created.
