Viewing 15 posts - 5,146 through 5,160 (of 6,389 total)
  • in reply to: Modbus TCP/IP Send different function codes #3153
    Modbus template editor http://doc.rapidscada.net/content/en/use-cases/modbus-protocol-files/modbus_template_en.png allows to change “Data table”. The function code depends on the selected item: Holding Registers, Coils, etc. You can see function code below the Data table combo box.
    in reply to: Подключение пульта С2000-М #3151
    Never use KP number 0. Make it greater that 0. Press a button (seems like a circle) to setup timeouts of the device.
    Also you have to switch S2000-M to the printer mode and setup sending events using the standard Bolid utility.
    To get answers in Russian, use http://forum.rapidscada.ru/
    in reply to: Observer pattern #3150
    Could you describe an example? Do you mean something like SNMP traps?
    in reply to: How can I do? #3146
    I can give advice in general or about available functions.
    in reply to: Telegram driver not activating #3145
    Provide screenshots, please.
    in reply to: Refresh time #3142
    The refresh time is the same for all the parameters. All the data are received by a single web request. Otherwise, would be not optimal. Use the smallest value of refreshing.
    in reply to: How can I do? #3141
    You should develop your own formulas that calculates average values and reset them when needed. You should enter the formulas into the Formulas table in Administrator and use them from input channels. Also you can purchase creating such formulas.
    in reply to: Roadmap #3137
    Definitely, very useful advice. Thanks!
    in reply to: Roadmap #3136
    If you decide to start a new development using Rapid SCADA as a platform, I think, we should discuss it, may be I can do advice based on the user feedback.
    in reply to: Roadmap #3135
    Thank you! I hope, I will do such section in the future. Currently let’s communicate here. Please create new topics if they are not related to the subject of the current topic.
    in reply to: Email sender bug #3134
    Thank you. I added this bug to the tracker.
    in reply to: PDF Reports #3133
    Can you provide a screenshot?
    Use styles:
    colStyle="col-lg"
    colStyle="col-sm"
    colStyle="col-xs"
    in reply to: SCADA Comunicattor – Events not received #3132
    You have a one input channel for a one tag.
    Event must be bound to a tag that is bound to a channel to be passed to Server.
    in reply to: SCADA Comunicattor – Events not received #3123
    I can’t see important data on the screenshot, because it’s cropped. Can you find that file in C:\SCADA\ScadaComm\Log and paste it here?
    in reply to: Scheme Editor #3122
    Zindex is an order of components one above another when they overlap. Use it for moving back and forward.
