Viewing 15 posts - 4,786 through 4,800 (of 6,391 total)
  • in reply to: Setting Alarm threshold #4147
    If the existing statuses are not enough for you, you can add your own statuses.
    in reply to: Setting Alarm threshold #4146
    How to change the channel Lower alarm limit; lower limit; upper limit; upper alarm limit ,from the web interface.
    You can’t. If you need to change limits, create additional input channel that represent limits. And then calculate a status of a controlled channel by your own formula.
    If using two channels for comparison,How to do change the event color?
    You need to set input channel status. A formula is like that: MyVal(); MyStat()
    where MyVal and MyStat are the functions that calculate value and status.
    Or just: Cnl; MyStat()
    If you don’t need to change value.
    Yes, you can find it in MasterMain.Master
    But there are also might be a product name in different files.
    According to the licence, you have to keep the information about the original product visible to a user. For example, keep the About page unchanged.
    in reply to: Rapid Scada Update and license key #4140
    OK,
    If it occurs again, please send me the log folders.
    in reply to: Rapid Scada Update and license key #4138
    Can you post here a link to download the full log folder of SCADA-Server when the issue occurs?
    The thing is that stopping procedure is simple, and it’s strange that the service can’t stop.
    in reply to: Intergration data input into cloud system #4137
    Likely, an integration software module should be developed to complete this task.
    in reply to: Formulas Math Functions #4136
    The example shows daily difference. Elastic Report also supports hourly difference. In case of 8 hours difference, we can discuss implementing this feature.
    in reply to: Formulas Math Functions #4135
    This calculation is difficult to implement using built in formulas because they work with current values. I suggest Elastic Report plugin, please check the demo which performs what you need.
    in reply to: Rapid Scada Update and license key #4131
    If you switch off Automatic Control Module, does the problem appear?
    in reply to: Rapid Scada Update and license key #4127
    Do you use Automatic Control module?
    in reply to: Adding link to chart view #4125
    Interesting and simple.
    in reply to: Display and Set the String Value for tag #4124
    Your formula is incorrect for binary command. It have to return array of bytes. Instead of CmdVal you need CmdData variable. I can write you a correct formula for a fee. Creating formulas is out of free support.
    in reply to: Rapid Scada Update and license key #4123
    Try the same configuration of Rapid SCADA on another computer to check if this issue constantly appears or depends on the particular PC.
    in reply to: Adding link to chart view #4119
    To use a link you need to update Rapid SCADA to the latest version.
    in reply to: Adding link to chart view #4118
    I see.
    Quick solution is using a link component on a scheme and specify an URL to a chart.
    The best solution is updating the web application to support the appropriate option. This could be done on commercial base.
