MikhailModeratorCan I do it for 2 conditions?
Yes.
a ? b ? c : d : eI forget how the above works ))
MikhailModeratorIn 2019 we may move to .NET 4.7, so you probably should think about upgrading the server OS.
.NET 4.7 is required to use the same .NET Standard DLLs with cross-platform .NET Core build of Rapid SCADA.
Press Ctrl+F5 to refresh all the scripts.
December 28, 2018 at 7:51 am in reply to: SCADAComm stop attempt to reconnect when communication failed #4790
MikhailModeratorIf you send me an email to info@ , I will forward your message to bersim.
You can try copying Web.config from the previous version. Does it help?
i fond that the log.bak file max. size is 1MB(1025Kb),not is 10MB
example : line050.log.bak 1025KBMy fault, sorry.
is there plan to provide config for log?
This issue is minor for the most users. We can do it faster for a donation.
MikhailModeratorThe components were published on July 30, 2018. So you need at least Webstation 5.0.6.1.
See the version history for the details.
When the log is more than 10 MB, it starts from the beginning. Currently, there is no option to change the max. log size.
MikhailModeratorThese are
SSCERuntime_x86-ENU.msi
SSCERuntime_x64-ENU.msiYou should install both of them.
MikhailModeratorThanks, I will check.
Can you tell the version of the Webstation app and of Extra Scheme Components Plugin?December 23, 2018 at 12:28 pm in reply to: Values sent from virtual MQTT devices not shown in Webstation #4767
MikhailModeratorI suppose, this issue needs debugging. You can do it by yourself or contact the author of the driver on GitHub.
MikhailModeratorHow to set condition in rapid scada scheme for the led indicator regarding to the formula above?
You need to create an new exrta channel in Administrator and bind a led to the new channel.
MikhailModeratorVal(n) is described here.
Expression a ? b : c is usual for C++/C# and means if a then return b else return c
MikhailModeratorCan you provide an example?
December 21, 2018 at 1:28 pm in reply to: Values sent from virtual MQTT devices not shown in Webstation #4758
MikhailModeratorThanks for the screenshot.
In the screenshot we see that /input/601 is bound to the channel #601 (because of the number in the Channel column). If there is no “15” in the UI, open the SCADA-Server shell, go to the Current Data node, open current.dat and view the current value of 601 channel. Is it 0 or “15”? -
