Thanks for noticing.
MikhailModeratorDashboard 5.1.0.0 requires Webstation 5.0.9.0.
You would recommend an update to SCADA 5.7.0?
Definitely.
Could you provide content of Communication Line Log page?
MikhailModeratorThis is a bad practice, because records still duplicated, but without error.
Somewhere in this forum or https://forum.rapidscada.ru/, a solution how to skip inserting duplicated records.
MikhailModeratorNow all the articles of http://doc.rapidscada.net/content/latest/en/ are updated for the version 5.7.
Click the left mouse button and hold it. Move mouse to the right. Release the mouse button.
Seems like version mismatch.
Please write here the version of Webstation and the version of Chart Pro and Dashboard.You can check the versions by yourself at http://doc.rapidscada.net/content/latest/en/version-history/
(release dates of the application and the plugins should be close)
In Webstation, click Main Menu > Reports and you will see it.
http://demo.rapidscada.net/Reports.aspx
MikhailModeratorDid you download 5.7.0?
Please provide more information how to reproduce to problem related to events. What plugin raises the error?
Please provide a screenshot.
MikhailModeratorI’ve just checked, the files are available. Strange.
I suggest Rapid SCADA 5.7.0.
What version do you download?
Where do you from?
Please try to do it using another PC.
> Please where can we define event instructions?
Please ask particular questions on the forum, and we will explain how it works.> how can we add user comments when acknowledge an alarm
Currently, this feature is not implemented.
C:\SCADA\ScadaComm\Log also contains lineXXX.log.bak, where you can find the previous part of the log. But this is also a part of log, not full.
May be we should add the option to set the log file sizes.
