Viewing 15 posts - 4,021 through 4,035 (of 6,391 total)
  • in reply to: Runtime Error on Rasbian after upgrade to 5.7.1 #6232
    Windows default folder configuration, which is obviously not working on Linux. After edeiting this it is fine again.
    That’s true.
    in reply to: Runtime Error on Rasbian after upgrade to 5.7.1 #6230
    1) Standard way:
    Uninstall Rapid SCADA according to uninstall.txt and then install the new version.
    However you can try to copy new files overwriting the existing. Don’t forget to register the Agent daemon, it’s important.
    2) It’s easier than earlier. Click the Deployment profile button. Create a new profile, specify your Linux machine in the profile. Upload the project to Linux from Windows computer.
    in reply to: Slave Device Failure #6229
    The register address looks strange. Try address 5-6 instead.
    in reply to: Slave Device Failure #6228
    You can successfully connect to the device. The device “understands” your requests and replies according the Modbus specification:
    Receive (2/2): 84 04
    Device error: [04] SLAVE DEVICE FAILURE!
    https://imgur.com/a/Y8H5iAE
    May be the device can’t get data from sensors?
    in reply to: Runtime Error on Rasbian after upgrade to 5.7.1 #6220
    1) Please provide the details of the question.
    2) Does your project currently work on Windows and you need to upload the project to Linux? Is the project upgraded to 5.7.1?
    3) I suggest configuring on Windows and then upload the project to Linux. To get a computer code, find it in the log of the module.
    in reply to: Slave Device Failure #6219
    Hi Kirjono,
    Please provide screenshots of the Communicator settings and copy a part of log file here.
    in reply to: Runtime Error on Rasbian after upgrade to 5.7.1 #6216
    Try searching for Global.asax in the ScadaWeb folder. There must be only 1 such file.
    May be some old DLLs were not deleted during upgrade. Delete all DLLs in ScadaWeb/bin folder and copy them again.
    in reply to: Runtime Error on Rasbian after upgrade to 5.7.1 #6215
    If you activated RAM drive as written in the installation manual, log files are stored in RAM and don’t exist after reboot.
    in reply to: How to setup Event #6214
    How do i flip the events such that the most current event is at the top.
    The event table automatically scrolls down when new event added if you don’t touch the table for some time.
    in reply to: Error updating the hourly data #6213
    Also try to edit the table view and hide tag by tag while the problem exists. You will find the tag that causes the problem.
    in reply to: Error updating the hourly data #6211
    i switch to network tab in chrome to find the appropriate response but i got totally confused
    Find there GetHourCnlData request and copy the response like that:
    {"d":"{\"DataAge\":[1576692000000],\"Success\":true,\"ErrorMessage\":\"\",\"Data\":[{\"Hour\":0,\"Modified\":true,\"CnlDataExtArr\":[{\"CnlNum\":101,\"Val\":34.799999237060547,\"Stat\":13,\"Text\":\"34.8\",\"TextWithUnit\":\"34.8 %\",\"Color\":\"Black\"},{\"CnlNum\":102,\"Val\":27.30000114440918,\"Stat\":14,\"Text\":\"27.3\",\"TextWithUnit\":\"27.3 °C\",\"Color\":\"Orange\"},{\"CnlNum\":103,\"Val\":27.875,\"Stat\":14,\"Text\":\"27.9\",\"TextWithUnit\":\"27.9 °C\",\"Color\":\"Orange\"},{\"CnlNum\":104,\"Val\":26.3125,\"Stat\":14,\"Text\":\"26.3\",\"TextWithUnit\":\"26.3 °C\",\"Color\":\"Orange\"},{\"CnlNum\":105,\"Val\":25.875,\"Stat\":14,\"Text\":\"25.9\",\"TextWithUnit\":\"25.9 °C\",\"Color\":\"Orange\"},{\"CnlNum\":106,\"Val\":99364.859375,\"Stat\":1,\"Text\":\"99,365\",\"TextWithUnit\":\"99,365 Pa\",\"Color\":\"Black\"},{\"CnlNum\":107,\"Val\":30.569999694824219,\"Stat\":1,\"Text\":\"30.6\",\"TextWithUnit\":\"30.6 °C\",\"Color\":\"Black\"},{\"CnlNum\":115,\"Val\":26.840625286102295,\"Stat\":14,\"Text\":\"26.8\",\"TextWithUnit\":\"26.8 °C\",\"Color\":\"Orange\"},{\"CnlNum\":119,\"Val\":745.297736244757,\"Stat\":1,\"Text\":\"745.3\",\"TextWithUnit\":\"745.3 mmHg\",\"Color\":\"Black\"},{\"CnlNum\":201,\"Val\":1,\"Stat\":1,\"Text\":\"On\",\"TextWithUnit\":\"On\",\"Color\":\"green\"},
    • This reply was modified 6 years, 10 months ago by Mikhail.
    in reply to: Necessary settings for "Export to Database Module" #6210
    You can find Calculator in the Administrator tree, send some data to SCADA-Server and check how these data exported.
    in reply to: Necessary settings for "Export to Database Module" #6209
    Output channels specify commands to:
    – Export current data
    – Export archive
    – Export events
    They are needed for manual export only. And you don’t need them for automatic export.
    in reply to: Runtime Error on Rasbian after upgrade to 5.7.1 #6202
    May be the web application has no access rights to write error in the log.
    Try providing full write access to /opt/scada/ScadaWeb/log and its content, restart computer, open the web page, and check the log file for additional information.
    in reply to: MQTT in-depth Installation Help #6201
    Thanks a lot for the video!
