Necessary settings for "Export to Database Module"
Forum Home › Forums › Communicating with Devices › Necessary settings for "Export to Database Module"
  • #6194
    Bojan
    I’m trying to use “Export To Database” module.
    I have created MySql table by the query from the manual and activated module ModDBExport.dll as present in the manual.
    Now I’m confused how to set channels according to following text in manual: To make manual export possible, create the corresponding output channels in the configuration database and specify them on the form. Could you give me some more info about this? If you could make an example for example for parameters which are part of your example table?
    #6195
    Bojan
    – How to set communication line
    – How to set the device
    – How to set channels
    – any other necessary settings?
    #6199
    In Administrator open the Output channel table and create 3 channels. Set the Standard command type, and the command value is Execute.
    In the module properties, specify the numbers of the output channels you created.
    If you share screenshots of the settings when you complete them, I can check.
    #6200
    For database export you don’t need to setup some special communication lines and devices.
    #6207
    Bojan
    Settings done, please check print screens:
    https://imgur.com/IP93eev
    https://imgur.com/nknaXke
    https://imgur.com/p9igInu
    https://imgur.com/pAOusqY
    Please comment, thanks!
    #6209
    Output channels specify commands to:
    – Export current data
    – Export archive
    – Export events
    They are needed for manual export only. And you don’t need them for automatic export.
    #6210
    You can find Calculator in the Administrator tree, send some data to SCADA-Server and check how these data exported.
