Viewing 15 posts - 3,991 through 4,005 (of 6,391 total)
  • in reply to: Help, command send now in Scheme Editor #6319
    Please create a separate topic. This topic doesn’t match the questions.
    Also provide an example that demonstrates how a system should behave.
    in reply to: Building the app error #6316
    Thank you for finding the cause. I will fix it in the project.
    in reply to: Automatic Control Module – Multiply triggers #6315
    Formula of output channel is calculated in a moment when a command is sent.
    in reply to: Automatic Control Module – Multiply triggers #6314
    Can I use ‘Formulas’ also for this purpose?
    What purpose?
    Does it work in output formula field?
    Such formula will work. But CustomFormula() == 1 …
    in reply to: connection status #6309
    when some device logon or logoff
    How a device do this?
    in reply to: connection status #6308
    Each topic should describe only 1 question.
    Please create a separate topic for the second question.
    And provide examples for the both cases to make them clear.
    in reply to: Building the app error #6306
    Try removing ScadaWebCommon5 dependency. Does it help?
    in reply to: Automatic Control Module – Multiply triggers #6305
    You should create a time trigger as usual. Then in the output channel formula, check
    Val(101) < -10 ? Cmd : double.NaN
    double.NaN cancels the command.
    in reply to: Slave Device Failure #6304
    I’ve realized that the address must be added by 1 since rapidscada address starting from 1 and device address starting from 0.
    You can change the starting address in the template settings.
    in reply to: Device error: [02] ILLEGAL DATA ADDRESS! #6303
    in reply to: Device error: [02] ILLEGAL DATA ADDRESS! #6294
    1. “easy modbus client” – is this a library or an application?
    2. Talking about Comap: “It is possible to disable requiring the access code in
    the configuration web page.” It’s from the manual.
    3. We can update the existing Modbus driver to send access code as a custom development.
    in reply to: Get username for the schema editor. #6293
    I think, it’s possible to develop a plugin that writes user ID and username into specified input channels when a user logged in.
    If you are a developer, you can do it by yourself. Or you can order development.
    in reply to: Device error: [02] ILLEGAL DATA ADDRESS! #6288
    Could you provide an example of correct communication? I mean content of packets.
    Many controllers support disabling of protection by a code.
    in reply to: Get username for the schema editor. #6287
    No, sorry.
    If needed, I can research whether it’s possible to implement this feature by development a custom plugin.
    Anyway, an input channel may contain only 8 Latin characters.
    in reply to: Elastic Report – xml configuration #6283
    and now I can use more easily ElasticReport with the calcType=”Diff”
    Nice that simple solution is possible.
    Formulas like “=SUM(RC[-3]:RC[-2])” generated by Excel. It’s impossible for human 🙂
