There should be 2 connections to SCADA-Server, by the users ScadaComm and ScadaWeb.
Please check what is written in ScadaServerSvc.txt about active connections.
Also check ScadaCommSvc.log and ScadaWeb.log
MikhailModeratorIn Administrator create a new deployment profile for Raspberry. Upload all the configuration except Server settings (because they have different file paths).
MikhailModeratorI would do the following:
1. Copy Communicator from the Linux installation package v5.6 to C:\SCADA\ScadaComm1
2. Copy Communicator from the Linux installation package v5.8 to C:\SCADA\ScadaComm2
3. Stop the existing Communicator service.
4. Copy the same configuration to ScadaComm1\Config and ScadaComm2\Config
5. Run ScadaCommMono.exe of different versions and compare.
MikhailModeratorDear Han,
– How to open on Web browser “Chrome”
Raspberry has Chromium browser. You can open it from the menu.
– How to open the Administrator?
In command line when you inside Administrator’s directory
mono ScadaAdministrator.exeHowever, I suggest avoid using UI on Linux. It’s better to configure projects and open web pages from another computer.
This reply was modified 6 years, 8 months ago by
MikhailModeratorGood news!
MikhailModeratorIt was a provider failure because of electricity break. Now it works. The first long interruption of service for several years of good operating. Thanks for noticing.
MikhailModeratorCommunicator works as system user, so it uses culture settings for “system”. I don’t recommend to change it, it may cause side effects. It’s just displaying that doesn’t affect real data.
You should open Administrator – Tools – Language and set fr-FR to apply culture settings to Rapid SCADA GUI and web interface. But currently the language pack doesn’t contain French. So settings affect date and number formatting. If you decide to create a translation to French and share it, I will assist you.
MikhailModeratorDear Mr.Han,
May be you should check timeouts.
Nothing changed in communication logic.
The screenshot is not available. Please upload it again.
MikhailModeratorjoeh6966, you should define the views exactly as it’s shown in the videos. No *.rsproj files there.
MikhailModeratorRead the document mentioned above. First, install new Rapid SCADA on another machine to test. Follow the document to convert the project.
MikhailModeratorUpgrade from v5.6 to v5.8 is similar.
MikhailModeratorThe default user Admin has full rights despite you fill the Rights table. Make sure that the view is opened if Admin is logged on.
MikhailModeratorDo I need to try out the Automatic Control Module to get what I want?
I think you should use formulas.
Do you get correct double value in Communicator? -
