There is not enough information about the system you build.
MikhailModeratorI don’t know if I need to use port forwarding on my router or use the firewall with advanced settings ?
Yes, you need to allow access from the Internet to LAN on the router. And also open an appropriate TCP port on Windows firewall.
MikhailModeratorIs it possible to run the HelloWorld project and DemoPrject simultaneously in one machine?
It is possible to install to different Rapid SCADA on a one machine, and run 2 projects. But it’s not so easy. If you need more info about it, please start a separate topic. It’s better to deploy 2 virtual machines.
However, they worked as intended when both options are checked during configuration upload.
You should analyze the log files of Communicator.
Does the OPC sniffer work with classic OPC (Midcrosoft OLE) or UPC UA?
Is it mandatory to restart server and communicator while uploading a project to RapidSCADA?
Agent automatically decides whether to restart or not. It depends what settings was changed.
Is it possible to run two different projects simultaneously on the same machine and view outputs on the webstation?
Do you mean to install 2 different Rapid SCADA on one machine?
MikhailModeratorMy be you need 2 different Rapid SCADA and 2 different projects.
The 1st project for simulating. And the 2nd project for control the simulated system.
MikhailModeratorCould you explain what is the reason of the 2nd instance?
For the 2nd instance, you need the 2nd deployment profile.
Address of the instance depends on the server where you deployed the instance.
MikhailModeratorThank you for reporting that the issue is resolved.
It’s possible to deploy 2 instances of the Webstation application. However, why not create 2 pages in a one Webstation?
MikhailModeratorHow can i create a new topic ?
Click the appropriate subforum, scroll the page down, fill and submit the form.
I need to setup two webstations.
Please create a new topic for this question.
May 14, 2020 at 4:20 pm in reply to: How to print the current configuration for the project documentation #6839
In Rapid SCADA 5.8 you can export tables of the configuration database in CSV format and then print them by Excel.
Configurations of the other applications are stored in XML files. You could open them in Notepad++ and print.
Some web sites don’t allow to display them in a frame. For example, Google.
To fix it, you need administrative access the website you want to display.
MikhailModeratorKeep scada.conf unchanged if you don’t change default installation directories.
This video answers your question.
Web application uses port 80. You should find and enable the existing rule in Windows firewall settings.
First of all, I must thank you for the wonderful job you’ve made (and keep making) with Rapid Scada. I learned a lot using it, aswell reading the forums.
