August 21, 2020 at 4:05 pm in reply to: push data to third-party station or another rapid scada station #7193
You should change settings in the XML file that is located inside your project directory.
Use this utility to encrypt password. We will develop user interface soon to edit the module settings.
This feature is already exists. Create different roles in the Roles table, configure rights for new roles, and assign roles to the users.
See this for more info.
Windows and Linux – yes. VM yes. I have no info about Mac.
Good! Does the whole system run well for now?
MikhailModeratorYou notified me that you have figured it out.
The above features can be done as a custom development by a contract. They are not included in the roadmap.August 18, 2020 at 12:25 pm in reply to: Digital Counter and calculate elapsed time for a channel in certain state #7177
Try the following:
Open Administrator – Server – Generator and send a new value to the appropriate input channel with status 1.
Does it help?
The both features require new developments.
MikhailModeratorThis was the last guess ))
MikhailModeratorTry uninstalling only the item “WCF Services” and then installing again.
The secret key is a string specified in C:\SCADA\ScadaAgent\Config\ScadaAgentConfig.xml on the remote server.
MikhailModeratorInstead of localhost you should specify the IP of the remote server.
MikhailModeratorIn what sequence do you install all of them after removing?
August 13, 2020 at 2:26 pm in reply to: push data to third-party station or another rapid scada station #7159
Install Rapid Gate only to the server that should push data to another.
The default configuration of the module is OK. Just set the target IP. -
