An input channel can store only 8 Latin characters, because channel value size is 8 bytes. SCADA mostly works with numbers than strings.
MikhailModeratorYou should learn the existing source code of the Login.aspx page, understand it, and then implement your own.
Please provide the report example.
Elastic Report allows to set a reading hour.
MikhailModeratorThe Agent service doesn’t work. If you need more info, create a new topic.
December 6, 2020 at 7:17 am in reply to: Website Artical section is down, can’t access dev guides #7673
Thank you. We will check and fix it.
Just copy the module files into /opt/scada/ScadaServer
Do you configure Rapid SCADA on RPi4 using Windows?
MikhailModeratorYou should try to download and setup the module. If you have questions during this process, please ask.
That means Press the Button, the value will be 1, released the Button, past some second, the value auto will be 0. I do likes that, don’t i?
I also would choose this method.
When a user click the button, the 1st command is sent. Then you need Automatic Control Module that triggers on the 1st command and automatically sends the 2nd command after the specified delay.
MikhailModeratorMessages are sent in UTF8. It’s here. If you provide a particular example, we can check it here.
MikhailModeratorIt always tell me the you look like spam
The is a protection plugin in the forum. The used rules like a back box. Without the plugin, there would be plenty of spam messages.
December 4, 2020 at 1:49 pm in reply to: Storing the result of a formula with Database Import Driver #7660
MikhailModeratorIs there a way to store data in a database automatically over time , without a prompt?
You should use DB Export Module of SCADA-Server instead of DB Import driver.
If I understood this correctly, the only way to save data is by sending a command, isn’t it?
It’s true for DB Import Driver.
This reply was modified 5 years, 10 months ago by
MikhailModeratorOn my Win10 machine Edge was automatically replaced to the new Chrome-based version.
Thank you for the script.
You can change AspectRatio parameter that affects height. But it doe not resize vertically automatically.Try using WebPage view if you need only 1 chart on a page.
MikhailModeratorAnd you need configure a router to forward the incoming requests to your Rapid SCADA server.
MikhailModeratorIf you need to access your office or home network from the internet, you need static IP address or dynamic DNS like https://www.noip.com/
In the deployment profile you can adjust the webstation URL
It just opens the specified URL. Doesn’t affect the real web site.
