Formulas check '-'
Forum Home › Forums › Understanding the Software › Formulas › Formulas check '-'
  • #5659
    scadarapid
    Hi.
    Can I use formula to check “-” value when the communication has lost.
    I use modbusRTU and I have a sensor which is discrete input register.
    When the communication has lost, I have noticed that my sensor value became “-” so, i need to check if my sensor has lost communication my output should be equal 150.
    public double check(double sensor)
    double output = sensor;
    if( sensor == null ){
    return output = 150;
    return output;
    Thank you so much.
    #5661
    scadarapid
    I use this formula but it does not work. when the communication has lost the output value become zero. but i need it to become 150.
    Thank you so much.
    #5662
    Look for formulas to check the signal status on the forum or try to change the formula to double.NaN
    #5669
    if (CnlStat > 0) …
    #5673
    scadarapid
    I use this formula to hold the old value and it works.
    Stat(2001) > 0 ? inputtest(Val(2001), Val(4003), Val(4002)) : Cnl
    Thank you so much
    #5677
    Take into account that
    CnlStat – the status that was just received from Communicator
    Stat(N) – the current status of an input channel before receiving new status
    #6969
    kumajaya
    Can we just have an option to hold last valid value?
    #6971
    Formula would be like
    CnlStat > 0 ? Cnl : Val(); CnlStat > 0 ? CnlStat : Stat()
