ModAutoControl – Trigger a command based on the change of a variable Forum Home › Forums › Understanding the Software › ModAutoControl – Trigger a command based on the change of a variable This topic has 2 replies, 2 voices, and was last updated 6 years, 3 months ago by athes. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts July 4, 2020 at 7:42 pm #6981 athesParticipant Hi Mikhail, I’m not able to trigger a command in AutoControl based on a variable change. The goal is to run a command if a value is higher or equal 4. My setup: https://drive.google.com/file/d/1EtO2E01FJ_bE1rlqM_hreleSbm4_Dhly/view?usp=sharing Obviously the Channel 1422 is valid, value changes between 0-10 during the day. The ModAutoControl.log is empty (the rest of the triggers are working well and fill the log) What should I change / check? July 5, 2020 at 7:45 am #6982 MikhailModerator Hi, You should use trigger on channel data, not on event. July 6, 2020 at 4:11 am #6983 athesParticipant Thanks Mikhail, This solved my issue. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
