Viewing 15 posts - 3,391 through 3,405 (of 6,392 total)
  • in reply to: Virtual Keyboard #8186
    Looks amazing! Thanks a lot!
    in reply to: Rapid SCADA tite text #8185
    Apache 2 license allows to create derivative products based on Rapid SCADA. So it’s possible not to show the original name in page titles.
    in reply to: Many dashboards pagination #8184
    in reply to: RapidGate v5.1.1.0 doesn’t work #8183
    Rapid Gate 5.1.1.0 requires Server 5.1.4.1. You should update Rapid SCADA to v5.8.2.
    in reply to: Virtual Keyboard #8161
    The 1st image is good, but the 2nd and the 3rd images does not open. Could you check the links?
    in reply to: Silent server crash #8151
    Thanks a lot. I will try to reproduce the problem using you project and write here.
    Adding 1s delay will reduce the probability / frequency of the server crash, but can not complete solve it.
    I mean adding a delay to a command in the module settings, not to request. If delay is added, commands are added to a queue instead of being sent directly. The queue should protect the server app from hanging.
    but I have no license of auto control module on my this computer
    Get a trial key https://rapidscada.net/trial/TrialKeyGen.aspx
    in reply to: No Communication now #8150
    as you have already refused to help me run Rapid SCADA on Linux Mint
    I don’t. Despite it’s more difficult to configure Rapid SCADA on Linux, Linux has significant benefits:
    – No licenses fees;
    – Reliability
    – Many people just love it.
    in reply to: Silent server crash #8142
    As a workaround of the hanging problem, I suggest to set delay of the command to 1 instead of 0. In this case command is send using a queue that is more reliable. Let us know about the result.
    in reply to: Silent server crash #8141
    Use a VPN in your browser, which should help you get access to image hosting services
    It may be complicated in China. If somebody has experience with that, please share.
    in reply to: No Communication now #8140
    Do you need help at the moment?
    in reply to: Internal server error (500) #8132
    Notification Plugin doesn’t work on Linux (it will be fixed in the future).
    Disable the Notification Plugin and restart Apache (or reboot the server).
    Is it possible to login Rapid SCADA?
    in reply to: Silent server crash #8131
    I was asking for a screenshot, not XML. I can check the settings if you provide it.
    in reply to: HTTPS on Linux #8130
    The content being embedded need to be changed to https too.
    Yes, because of the browser protection.
    Thank you for the details.
    in reply to: ModDBExport module is not working in Ubuntu #8129
    Thanks for the recipe.
    I am pending if you set up a standard solution for this issue.
    There is a update for PostgreSQL connector, but it has a lot of dependencies and it’s better to use it with .NET 5. In the future Rapid SCADA will be ported to .NET 5, and this should solve the problem.
    in reply to: Table View transposition & max present tavle values #8128
    You need 2 records in the Interface table: one for the report and the 2nd for the link.
