Hello.
I’m learning SCADA via Rapid SCADA.
I successfully installed and setup first pair of Rapid SCADA instance.
my laptop server and pi communcator is communicate real time.
I want to make double pair on same laptop for other pi.
but I can’t found any way for make double.
I understood there is a way, that is 1 profile having 2 communicator line.
but this case SCADA Web displaying same view and communicator data is mixing in database, because we are using same Server.
I want to seprate between old one and new one.
If I possible, I want to make double SCADA system on same machine.
so,
I want to know these.
1.
I were using ‘default profile’.
If I add new profile, is it work sepratly on same Server?
How to setup?
2.
Could I install and setup multiple ScadaServer seperate by port on same machine ?
if it can be, how to it?
what files need for copy?
please let me some advise.
Thanks & Regards.
