Viewing 15 posts - 3,301 through 3,315 (of 6,392 total)
  • in reply to: OPC no values #8416
    I can connect to opc.tcp://83.42.220.118:4840
    I will check and write here
    in reply to: Rpi 4 Rapid Scada web station table #8410
    Where is the data stored before it is displayed on the web server?
    /opt/scada/ArchiveDAT
    You can copy the data files to Windows and view them by the utility.
    When I view the table on the web station the data is from the first acquired data, it does not change as if it is frozen.
    This is odd. Could you provide a link to a screenshot?
    in reply to: auto started pure display board #8409
    1. Search for browser kiosk mode. It’s already solved.
    2-4. It would be useful. Agree with you.
    5. Set event count to 0 in the web app settings.
    Thank you for the idea.
    in reply to: rapidgate module bug #8408
    I suppose, this update should be officially released soon.
    but the register computer code is different from other computer code.
    It’s not related to the module version.
    in reply to: excel export question #8407
    It’s a special format supported by Excel and Libre Office (XML Table 2003, Spreadsheet ML). It’s not XLS nor XLSX.
    in reply to: OPC no values #8406
    How money?
    Please contact us by email to get an offer.
    And we can proceed for free if you manage to open a connection.
    in reply to: Scada Agent error #8389
    First of all, check that the link, created by ln command, works correctly. You can check it by clicking the link in WinSCP, for example.
    in reply to: rapidgate module bug #8388
    If you mean this Rapid Gate Update, this is a good version.
    By this link you can see:
    ModRapidGate 5.1.1.1 (In development)
    - Fixed an issue when starting the module
    Does the update work correctly?
    in reply to: OPC no values #8387
    Connecting to a computer by remote desktop (or similar tools) is a paid service.
    I can help you for free if you open access to OPC server, so I can run OPC UA client on my computer to debug. To do this, you should configure port forwarding on a router.
    in reply to: Forwarding the Rapid scada web on Ubuntu #8386
    To make the web application available from the internet you should open the port 80 for HHTP and port 443 for HTTPS. You should search how to open these TCP ports on Google cloud.
    in reply to: l #8381
    No. But scheme templates may help (scroll the page down to Scheme Templates).
    in reply to: Scada Agent error #8378
    It may be an access rights problem.
    When link is created, it works similar like copying files into the target directory.
    in reply to: sec data save #8377
    I also suggest to map log directories to RAM disk.
    in reply to: Custom Page #8376
    Use getCurCnlDataExt function. If you run file search of “getCurCnlDataExt” on *.js files, you will find examples in the Table and Scheme plugins.
    in reply to: Export to SQLite #8375
    SQL requests are executed by the module every time when data are sent from Communicator to Server. So the logic to store data with particular interval should be implemented on the DB level.
    However, in 2021 we plan to release an update of DB export module to be able to upload Rapid SCADA historical archive to a DB. This feature may be useful in your case.
