Viewing 15 posts - 3,241 through 3,255 (of 6,392 total)
  • in reply to: Transfer File from Computer to Rpi #8579
    Thanks for the useful notes. Some comments below.
    I then went through Administrator on windows and changed all localhost settings to now look at the remote server eg. 192.168.1.10
    Could you provide a screenshot of this to check?
    This is most likely a config issue but I had to re transfer all the plugins to the Rpi opt/scada/ folder
    DLLs of the modules should be presented on RPi. WinSCP is good for file transfer.
    To activate the ChartPro plugin, I had to go chmod ug+rw WebSettings.xml
    This is a known issue. We will fix it in the future.
    in reply to: Sendig email: Error: incorrect command data #8577
    Please open the properties of KpEmail.dll and check the version. What is the file version?
    Also try specifying a particular email:
    test@gmail.com; Subj; Text
    in reply to: Sending a Signal to a Scada Unit #8572
    You can’t send a command from a formula. However, you can set input channel value from a formula.
    To send commands according to conditions, Automatic Control Module was created.
    in reply to: Few question about avialable feautres #8571
    Currently to export data on change, use the existing DB export module.
    The version 5 can only export data to 3rd party DB. Flexible archives possible in v6.
    in reply to: LED not working at output channel #8567
    Output channel only declares a command. It doesn’t send command itself, and it doesn’t store any value.
    To display any kind of value, you need an input channel which stores a value.
    in reply to: Sending a Signal to a Scada Unit #8566
    If you need to send commands automatically according to some conditions, Automatic Control Module would help you.
    in reply to: Few question about avialable feautres #8562
    I hope till the end of 2021. But it is not exactly.
    in reply to: LED not working at output channel #8561
    Led can blink if you bind it to input channel. You should create a formula that changes input channel value every second, for example.
    Something like
    public double Blink()
      return DateTime.UtcNow.Second % 2 > 0 ? 1 : 0;
    Then use this formula in the input channel row.
    in reply to: Sending a Signal to a Scada Unit #8560
    Do you use Modbus protocol?
    If yes, you should create a command in the Modbus template. Then check the command by sending commands from Communicator.
    Output channel is also needed. Please provide screenshots.
    in reply to: Few question about avialable feautres #8556
    – Can you show to user when data was last updated?
    Yes, using a custom formula plus extra input channel.
    – If we use Chart Pro plugin can we have pie charts or some other charts?
    No. May be you should integrate with Grafana. There is a plugin available.
    – And can we have multiple variables on 1 graph?
    Yes, you need Chart Pro.
    – If we use Automatic control module can we send custom email for different alarms?
    Definitely.
    – Or is this possible without plugins?
    I think, no.
    – Is it possible to trigger alarm and send email if we lose communication with one of devices?
    Yes. You can trigger on channel status = 0 and/or events.
    For more details, please start new topic for a particular question.
    in reply to: Few question about avialable feautres #8554
    As you said you have your custom format for saving data and you don’t use DB. Can you tell how much would it cost if you would add option that data is saved to archive just on change?
    Please wait for version 6 for this feature.
    If I understand each object means like a “factory” or “part of factory”. Is it possible to see big is archive for each object?
    Archive size depends on number of input channels and saving period. You can collect data for 1 day and then divide by channel count.
    in reply to: About Elastic Report Month Period #8552
    Enter a title in the Interface table in the Title column.
    in reply to: Sendig email: Error: incorrect command data #8551
    Please try the update
    At least it writes more info in communication line log in case of incorrect data.
    in reply to: Computer code for plugin #8550
    Did you install Chart Pro?
    After step 4, there will appear a registration menu item in the web application which contains the code.
    in reply to: Few question about avialable feautres #8545
    – Mqqt what format is supported, can we have our own protocol inside MQQT? Is it possible to send data with timestamp?
    Could you explain how to insert other protocol inside MQTT?
    – If it’s possible to send data with timestamp, can you send/insert data for the past(like yesterday).
    Yes. But MQTT works with current data. You should look for Enron Modbus and OPC UA, for example. Probably, driver update would be required to support reading archive. In general, it’s possible in Rapid SCADA.
    – In Rights table I can’t select interface, so that I would assignee user access to interfaces.
    – Can you save data to db just on change?
    You can do it using Database export module. In Rapid SCADA v6 we will extend this capability.
    – Can you export data from DB to .cvs in selected time frame? Can you append name to data? If I export data from Administrator -> Archive there is just number of the input in input channel.
    We can develop a required application by a contract if needed.
    – I see that you can access data in archive. Is it possible that data is saved to archive just when value is changed and not every minute?
    See above.
    – Can you edit or delete part of the archive (from date to date)?
    You can delete daily data, because every day new file is started.
    – Can we see how much data is there for each object?
    Please clarify.
    – What database is Archive using?
    Rapid SCADA uses our own engine, no 3rd party DB required. In version 6 we also will support InfluxDB and PostgreSQL.
