Viewing 15 posts - 3,121 through 3,135 (of 6,392 total)
  • in reply to: event triger #8937
    1. Set Signal to blank
    2. Update the formula to GetBit(Val(1001), 0); GetBit(Val(1001), 0) > 0 ? 116 : 115
    in reply to: scheme editor #8933
    @q383186554, your developments are quite interesting.
    When you create a production version, let the people know about that.
    in reply to: scheme editor #8932
    will the V6 version save current data per second?
    It will write data to archives with any period.
    I have a new idea about the scheme editor. the web station does not have self-adapting in different screens on different DPI. do you have a plan to solve that?
    It is not a scheme approach. I would call it dashboards. The existing Dashboard plugin also uses Bootstrap. Welcome the creation of different types of views.
    Is the transmitter manual available?
    in reply to: event triger #8930
    The formula is incorrect. Could you provide a screenshot of all properties of this channel?
    in reply to: Cant even login Raspberry Pi 4B Ubuntu 21.04 #8929
    Internet Explorer is not supported. You should use modern browsers like Chrome, Firefox or Edge.
    in reply to: scheme editor #8912
    The mentioned drivers and modules are very useful. That’s great!
    Are documentation or videos available?
    Do you have plans to spread the modules?
    in reply to: event triger #8911
    May be events are created but not displayed. Did you click “All Events” button of the events table?
    Also you should open the archive files in Administrator and check if events presented or not.
    If you change language to English, open channel properties form, and make a screenshot of all channel properties, it would help.
    in reply to: OPC on Remote PC #8910
    You also could watch this video about OPC UA configuring.
    in reply to: OPC on Remote PC #8909
    Please provide more details of you task.
    OPC DA and OPC UA are supported by different Rapid SCADA drivers, and they are configured differently.
    in reply to: Cant even login Raspberry Pi 4B Ubuntu 21.04 #8908
    Does raspbian differ from Ubuntu in the process?
    If you mean the process of Rapid SCADA installation, it’s similar.
    in reply to: scheme editor #8897
    Align feature will be added, because it’s really needed.
    Thank you for additional notification about that.
    You need:
    1. Specification of the communication protocol between computer and the transmitter.
    2. Develop a driver (.NET assembly, C# language) that implements that communication protocol.
    in reply to: Change event type color #8895
    When enumeration includes 2 values, colors always red (0) and green (1).
    Just add any 3rd value of the unit.
    Are there channels 9602 and 9603 in the screenshot or others?
    in reply to: 65535 limit #8894
    You should create a new topic, because the subject of the current topic is different.
