Viewing 15 posts - 3,001 through 3,015 (of 6,392 total)
  • in reply to: Installation failure #9292
    Links to the docs and videos are here.
    in reply to: Signal Relative ID to Fixed ID ? #9287
    Thanks for the idea. Added to the wishes list.
    in reply to: KpMQTT and Thingsboard #9286
    You need to parse the response using JavaScript engine of the driver.
    kp_mqtt_5.0.4.0.zip contains KpMqtt_Job.js which can be used as example.
    But string values are not supported. Can you change method value to a number?
    in reply to: Retriveing DataSlice timestamp ? #9284
    Current data has not timestamp in assumption that the time is now.
    When new data is coming to an input channel, you can write a timestamp to another input channel and then send it by MQTT.
    in reply to: webpage develop #9280
    I’ve replied by email. Thank you.
    in reply to: webpage develop #9277
    The Webstation app stores login info in the HTTP session. I suppose, you need a small plugin written in C# that performs login for you. For example, AutoLogin Plugin.
    in reply to: How to use Notification plugin? #9275
    If you mean the crash caused by Notification Plugin, it will be fixed only in v6, because it’s something deep in the Mono framework.
    in reply to: Installation failure #9274
    OK
    in reply to: Installation failure #9271
    You could also ask in this new subforum.
    in reply to: scada 3d develop #9270
    Very cool!
    in reply to: How to use Notification plugin? #9269
    what’s the function of tag?
    IDs of the quantities to show in the notification panel.
    Is it possible to limit the notification to certain channels only?
    No, only the filters presented in the configuration file.
    Is is possible to have event on status 4 changed?
    Could you explain this question?
    Note: Notification plugin does not work on Linux because of Mono bug. The web app hangs.
    in reply to: Installation failure #9268
    I don’t understand what is written in Chinese.
    Run services.msc and make sure that ScadaServerService exists in the list.
    in reply to: scada forum #9262
    I’ve kept the both branch names.
    in reply to: Installation failure #9259
    I mean, what do you get in command window when execute *.bat files?
    in reply to: scada forum #9254
    Let’s try 🙂
    I granted rights to you, but I’m not sure how they work. If there will be inappropriate statements, advertisement or spam, let me know.
