Viewing 15 posts - 2,731 through 2,745 (of 6,392 total)
  • in reply to: How to quickly add OPC channel #10141
    but it didn’t seem to work
    What exactly?
    in reply to: How to quickly add OPC channel #10140
    I think, you are on the right way.
    You can copy KpOpcUa*.xml and then edit it with XML editor like Notepad++.
    To find what lines should be edited, create 2 files manually, then compare them using WinMerge free app.
    in reply to: Контроллер домена #10136
    May be the translation of the question is not exact.
    Please explain what IP and port do you need to set.
    Note: please write in English on this forum. Also there is a subforum in Chinese.
    in reply to: Контроль доступа #10135
    Access rights are applied to a view like scheme or table.
    in reply to: Runtime Events #10128
    You could try the following:
    1. By default, there is a delay 200 ms after each request. You can set it to 100 ms in the device options, for each device.
    2. Split the communication line into 2 communication lines. They work in parallel.
    in reply to: OPC DA #10124
    Please upload screenshots to some cloud drive to be able to see them.
    in reply to: Runtime Events #10122
    Please provide screenshots of the Communicator settings and communication line log.
    in reply to: Sending Command values without password #10121
    1. Open https://localhost/scada/plugins/Config/WebConfig.aspx
    2. Untick “Require password to send command”
    3. Press “Save Configuration”
    4. Download configuration changes into your project by the Administrator app
    in reply to: Sending Command values without password #10117
    The required option to disable password is presented in the Web application configuration.
    in reply to: Send/Import data with timestamps from a driver #10114
    I can’t understand Rapidcada structure yet
    Ready to help if you ask more questions.
    in reply to: Rapid SCADA 6 Beta #10113
    Hello Matt,
    Thank you for the bug report. It is fixed now, and the fix will be included in the next beta release.
    Currently, you could manually edit a path in C:\Users\YOUR_USER\AppData\Local\ScadaAdmin\Config\ScadaAdminConfig.xml
    in reply to: TCP Api #10110
    To open some web page automatically, you need an application that runs with a user account. Server runs as system service, so it’s not possible to start any UI from formulas.
    in reply to: config file hot reload #10107
    We plan to develop a module that allows to change the following configuration in runtime without restarting:
    1. Users
    2. Channel limits
    in reply to: config file hot reload #10106
    If channel configuration changes, it requires compiling scripts, initializing of archives and modules.
    I agree that it would be good, but I don’t see easy way to implement it and make reliable.
    In v6 it’s possible to restart communication lines if Communicator configuration changes.
    in reply to: An error #10104
    Please provide screenshots of the communication line and device settings and communication line log that demonstrate the issue.
    What type of connection is used?
