Viewing 15 posts - 2,551 through 2,565 (of 6,392 total)
  • in reply to: Two or More Scheme diagram #10662
    Each scheme is a one webpage. To select a scheme, a user clicks it in the view tree.
    in reply to: Error code #10656
    You should check communication line log for the error details.
    • This reply was modified 4 years, 1 month ago by Mikhail.
    in reply to: Scheme Editor #10655
    May I have any comments for the toggle problem encountered?
    Please provide more info:
    – screenshots of the existing settings
    – actual behavior
    – expected behavior
    in reply to: Flashing effect at scheme diagram #10654
    You should try to use animated GIF in Scheme Editor with a Dynamic Picture component.
    in reply to: Modbus Device via Scheme Editor #10653
    To fix this issue, screenshots are required.
    in reply to: Donation #10628
    We provide some commercial modules and paid services. We appreciate if you use them.
    Before purchasing modules, make sure that the modules work as you need.
    in reply to: server is unaviliable #10627
    The structure of Rapid SCADA directories is broken.
    I recommend to reinstall Rapid SCADA with the default parameters.
    in reply to: Scheme Editor #10626
    What is meaning for this based on the status color?
    Component color may depend on channel status.
    LED – SEND COMMAND, it will be execute my command from input channel after certain time delay.
    Action executes on user click.
    in reply to: Scheme Editor #10625
    Kindly help to clarify if the action for draw diagram is to draw a diagram for user?
    Yes, the Draw Diagram action means that a chart will be open when a user clicks the component.
    The Send command action opens the command dialog.
    The Send command now action send a command without a dialog.
    in reply to: Command Error #10624
    To copy a log, find the file on disk in C:\SCADA\ScadaComm\Log, open in text editor, and copy.
    Screenshot also OK.
    in reply to: Command Error #10616
    Could you provide communication line log in the moment when error command is sent?
    in reply to: server is unaviliable #10615
    Could you provide screenshots of the Server settings in the project?
    Did you uploaded the project after settings change?
    in reply to: Rapid SCADA 6 Beta #10612
    The release is planned for this year.
    Choosing between version 5 and 6 depends on the requirements of the system you are working on. If you describe the requirements, I could suggest the version.
    in reply to: server is unaviliable #10611
    You should check that the directories specified in the project for the Server application, actually exist on the disk.
    in reply to: TCP Client Modbus RTU #10610
    To reduce the list of combinations, describe what result do you need.
