windows 11 dot net framework has v.4.8. Can’t receive/ install on Dot net version 4.6.
Rapid SCADA 5.8.4 Installation
Install Server application
Installation of Server application has completed with a error:
Directory C:\SCADA\ScadaServer has to be cleared
Directory C:\SCADA\ArchiveDAT has to be cleared
Directory C:\SCADA\ArchiveDATCopy has to be cleared
Directory C:\SCADA\BaseDAT has to be cleared
Directory C:\SCADA\Interface has to be cleared
Install Communicator application
Installation of Communicator application has completed with a error:
Directory C:\SCADA\ScadaComm has to be cleared
Check the configuration of Internet Information Services (IIS)
Go to
Control Panel > Programs > Turn Windows features on or off
and make sure that WCF Services > HTTP Activation feature is installed for .NET Framework 4+,
whereas the components for .NET Framework 3.5 are switched off
Check Windows Communication Foundation (WCF)
Register ASP.NET
Install Webstation application
installation of Webstation application has completed with a error:
Directory C:\SCADA\ScadaWeb has to be cleared
Install Agent application
Installation of Agent application has completed with a error:
Directory C:\SCADA\ScadaAgent has to be cleared
Installation of Administrator application has completed with a error:
Directory C:\SCADA\Projects has to be cleared
Install Scheme Editor application
Installation of Scheme Editor application has completed with a error:
Directory C:\SCADA\ScadaSchemeEditor has to be cleared
Install Table Editor application
Installation of Table Editor application has completed with a error:
Directory C:\SCADA\ScadaTableEditor has to be cleared
Installation has completed with errors
