MikhailModeratorStart Internet Information Services (IIS) Manager, select the application pool used for Rapid SCADA, open Advanced Settings of the application pool, and set the following options:
General – Start Mode: AlwaysRunning
Process Model – Idle Time-out: 0
Recycling – Regular Time Interval: 0
MikhailModerator🙂
MikhailModeratorIf the both versions are installed in parallel, there will be a conflict, because they use the same TCP ports. It’s better to uninstall the older version first. Or use virtual machines for different versions.
Please use documentation for version 5. The visual changes are not too big. The most changes were made inside the engine.
User interface of Communicator is integrated in the Administrator application.
ScadaCommCtl.exe is for very old versions.
Yes, Rapid SCADA 5.8.4 includes OPC UA client driver. Configuration of OPC UA driver is similar to OPC Classic driver.
I suggest Rapid SCADA 6 for new projects, because it is more simple to configure.
MikhailModeratorHi Mark,
openPLC supports Modbus communication protocol. So it can be integrated with Rapid SCADA. This article describes how to configure Modbus on Rapid SCADA.
For new projects I suggest to download Rapid SCADA 6.
According to the provided line013.log, Telegram Driver requires a valid registration key.
MikhailModeratorThe creation of a generic mechanism should be done by our resources. Plugins can be developed by 3rd parties, by us, or sponsored.
On a one hand, the captcha is big, while on the other hand, it’s comfortable readable by humans on computer screens and gadgets. We use only digits to make captcha more international.
Use Google or Microsoft token to implement 2FA for enhanced login security. Is this possible to be included in the future plan?
Thank you for this idea. First of all, we should provide a generic mechanism to allow using additional plugins for external auth systems. Then implement such plugins. I’ve added it to the wishlist.
MikhailModeratorIf I change the service startup type from automatic to automatic (delayed) startup, the 3 services of rapidSCADA can start normally.
I don’t know why there is no need to set the delay in win 10 desktop version but it needs to be set in win server 2022.
do you have encountered such a case before?This is a weird thing. Thank you for finding a workaround.
We haven’t met this before. However, as for me, I haven’t tried Windows Server 2022 yet.
In case I got new related info, I will text here.
Mono 6.12.0.122 is up to date.
But in the screenshot https://imgbb.su/image/xTz7FM the error is in Mono.Security.dll 4.0.0.0. Could you search for Mono.Security.dll inside subdirectories of /opt/scada ?
If you found Mono.Security.dll there, delete it and restart the Rapid SCADA services.
Components contain C# and JavaScript code. They are loaded and created by Scheme Editor.
Source code of scheme components for Rapid SCADA 5 is here.
If you have certain questions, ask.
MikhailModeratorThank you for your care.
According to the messages, Server started successfully when executed manually.
Could you try executing svc_stop.bat and svc_start.bat from command line as administrator.
What is written in SCADA\ScadaSever\Log\ScadaServer.log ?
MikhailModeratorLooks correct.
What if you open command line as administrator, find and run ScadaServerWkr.exe?
MikhailModeratorYou understanding is correct.
Please run from a command line:
dotnet --info
What does this command return? -
