laihParticipantSend /1004/command = {“Val”:0}
@val Why is the value 0? I wrote the value in the “send command”, but it didn’t work. An error “invalid command” occurred.
laihParticipantthere is my logs.
2026-07-23 15:23:30 Connect to 192.168.31.183:1883
Connected successfully2026-07-23 15:23:30 Subscribe to topic
Subscribed successfully. Topic count: 12026-07-23 15:23:59 Receive /v1/devices/1004/datas = {
“humidity”:15,
Subscribed devices: 4
Error: Could not find a part of the path ‘C:\Program Files\SCADA\ScadaComm\Config\’.2026-07-23 15:33:44 Receive /v1/devices/1004/datas = {
“humidity”:15,
laihParticipantHow do you add components in the new web configuration designer Mimics? Is it the same as the method used in the old web designer version?
laihParticipantI’ve figured out the problem. It’s that I didn’t write the namespace correctly.
laihParticipantAre there any diagrams with a file structure? Or should I first install the program, obtain the file structure, and then replace the corresponding files during the debugging process?
laihParticipantI know there is an example project. But I would like to know how to use the built files shown in the screenshot to make the rapidScada Scada program run.This is my screenshot.
laihParticipantok
laihParticipanthttps://i.postimg.cc/QtFq536n/Snipaste-2025-07-07-18-05-44.jpg This is a screenshot from my design process.
laihParticipant我在automatic control中添加好命令后,在哪里使用呢
laihParticipant找到了,是web工程编译有问题
