Using the MQTT client driver, an error occurred.
Forum Home › Forums › Communicating with Devices › Using the MQTT client driver, an error occurred.
  • #18172
    laih
    When using the MQTT client driver, I have connected to the MQTT broker and can view the message logs of the subscribed topics in the communication log. However, after enabling JavaScript, when I ran it again and received the subscribed messages, an error occurred: “Error: Could not find a part of the path ‘c:\program files\SCADA\ScadaComm\Config\'”.
    I know this is caused by the lack of the JavaScript file. But how should I create and configure this JavaScript file?
    #18173
    laih
    there is my logs.
    2026-07-23 15:23:30 Connect to 192.168.31.183:1883
    Connected successfully
    2026-07-23 15:23:30 Subscribe to topic
    Subscribed successfully. Topic count: 1
    2026-07-23 15:23:59 Receive /v1/devices/1004/datas = {
    “humidity”:15,
    Subscribed devices: 4
    Error: Could not find a part of the path ‘C:\Program Files\SCADA\ScadaComm\Config\’.
    2026-07-23 15:33:44 Receive /v1/devices/1004/datas = {
    “humidity”:15,
    #18177
    The *.js files should be located in your project among Communicator configuration files. Also specify the short file name in the device properties. The script example is here.
