development web plugin-no.1 Forum Home › Forums › Development and Integration › development web plugin-no.1 Tagged: Web Plugin development question This topic has 5 replies, 2 voices, and was last updated 9 months, 1 week ago by Mikhail. Viewing 6 posts - 1 through 6 (of 6 total) Author Posts November 13, 2025 at 12:48 pm #17298 laihParticipant While referring to the addition section of the web plugin documentation, I carried out the operations as described in the document, but the following result was obtained. result_picture_link This topic was modified 9 months, 2 weeks ago by Mikhail. November 13, 2025 at 12:58 pm #17300 laihParticipant I’ve figured out the problem. It’s that I didn’t write the namespace correctly. November 14, 2025 at 1:42 pm #17303 MikhailModerator OK November 18, 2025 at 3:14 am #17319 laihParticipant How do you add components in the new web configuration designer Mimics? Is it the same as the method used in the old web designer version? November 18, 2025 at 12:17 pm #17321 MikhailModerator It’s different. It’s mostly implemented using JavaScript and a bit of C#. See the example here. November 18, 2025 at 12:18 pm #17322 MikhailModerator If you ask about installation, file copying is required to ScadaWeb and ScadaAdmin folders. Author Posts Viewing 6 posts - 1 through 6 (of 6 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
