webStation 无法登录 报错 没有配置数据库,表未定义
Forum Home › Forums › Questions in Native Languages (Experimental) › Questions in Chinese. 中文问题技术交流 › webStation 无法登录 报错 没有配置数据库,表未定义
  • #14943
    laih
    2024-07-15 14:36:25 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ACT] Webstation 6.2.0.1 started
    2024-07-15 14:36:25 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ACT] Storage FileStorage 6.2.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\FileStorage.dll
    2024-07-15 14:36:25 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ACT] Plugin PlgChart 6.0.2.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgChart.dll
    2024-07-15 14:36:26 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ACT] Plugin PlgMain 6.0.3.1 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMain.dll
    2024-07-15 14:36:26 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ACT] Plugin PlgScheme 6.0.2.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgScheme.dll
    2024-07-15 14:36:26 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ACT] Plugin PlgSchBasicComp 6.0.2.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgSchBasicComp.dll
    2024-07-15 14:36:26 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ERR] Unable to create plugin logic PlgStore. File C:\Program Files\SCADA\ScadaWeb\PlgStore.dll not found
    2024-07-15 14:36:26 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ACT] Plugin PlgWebPage 6.0.2.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgWebPage.dll
    2024-07-15 14:36:26 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
    2024-07-15 14:36:26 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
    2024-07-15 14:36:26 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ACT] Receive the configuration database
    2024-07-15 14:36:27 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ERR] Error receiving the configuration database, the Undefined table:
    System.NullReferenceException: Object reference not set to an instance of an object.
    at Scada.Web.Code.WebContext.PostprocessConfigDatabase(ConfigDatabase configDatabase) in D:\SourceDev\Scada\scada_v6\ScadaWeb\ScadaWeb\ScadaWeb\Code\WebContext.cs:line 415
    at Scada.Web.Code.WebContext.ReadConfigDatabase(ConfigDatabase& configDatabase) in D:\SourceDev\Scada\scada_v6\ScadaWeb\ScadaWeb\ScadaWeb\Code\WebContext.cs:line 366
    2024-07-15 14:36:36 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ACT] Receive the configuration database
    2024-07-15 14:36:37 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ERR] Error receiving the configuration database, the Undefined table:
    2024-07-15 14:36:46 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ACT] Receive the configuration database
    2024-07-15 14:36:47 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ERR] Error receiving the configuration database, the Undefined table:
    2024-07-15 14:36:56 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ACT] Receive the configuration database
    2024-07-15 14:36:57 [DESKTOP-O4C07J5][DESKTOP-O4C07J5$][ERR] Error receiving the configuration database, the Undefined table:
    #14959
    Zeus
    空指针了,应该是配置不对
    #14964
    laih
    找到了,是web工程编译有问题
