manual build Scada, running Scada
Forum Home › Forums › Development and Integration › manual build Scada, running Scada
  • #17272
    laih
    After manually building all the projects, how does rapidScada run them manually using the files generated during the build process?
    • This topic was modified 1 year ago by Mikhail.
    #17279
    An engineer sends a project for execution. Then the project is executed by the services such as Server, Communicator and Webstation.
    #17285
    laih
    I know there is an example project. But I would like to know how to use the built files shown in the screenshot to make the rapidScada Scada program run.This is my screenshot.
    #17288
    After build, the result files should be copied according to the file structure as they are presented in the installation package.
    #17299
    laih
    Are there any diagrams with a file structure? Or should I first install the program, obtain the file structure, and then replace the corresponding files during the debugging process?
    #17305
    Yes, you right. This is the most optimal way.
