ipqiushengParticipantHi
Mikhail and other guys, do you know what’s parsedData define?, it has property of ViewStamp and SchemeDoc object?
scada.scheme.Scheme.prototype._obtainSchemeDoc = function (parsedData) {
try {
if (typeof parsedData.ViewStamp === “undefined”) {
throw { message: “ViewStamp property is missing.” };
}if (typeof parsedData.SchemeDoc === “undefined”) {
throw { message: “SchemeDoc property is missing.” };
}if (this._viewStampsMatched(this.viewStamp, parsedData.ViewStamp)) {
this.type = “”;
this.props = parsedData.SchemeDoc;
this.viewStamp = parsedData.ViewStamp;
return true;
} else {
return false;
catch (ex) {
console.error(scada.utils.getCurTime() + ” Error obtaining scheme properties:”, ex.message);
return false;
ipqiushengParticipantthanks for your reply
Mikhail, I have used github to find this popup.js in webshell project, so I can’t find that in plscheme files. just mark here for other guys if someone have interesting in your code
ipqiushengParticipanthi
I put the link below my comments
ipqiushengParticipantalso, in basiccomprender.js, it also existed
sorry, I haven’t use version 6.0, I still look at your version 5.0 code, your code is very elegant,I still look at that, this is version 5.0 code, the popupLocator existed in schemerender.js. not sure where it is defined, but it looks like define in viewhub.js, but I can’t find that.
https://github.com/RapidScada/scada/blob/master/ScadaWeb/ScadaScheme/PlgScheme/plugins/Scheme/js/schemerender.js
ipqiushengParticipantscada.scheme.SchemeRenderer.prototype._setTitle = function (title, renderContext) {
if (title && renderContext.schemeEnv.viewHub) {
document.title = title + ” – ” + renderContext.schemeEnv.viewHub.getEnv().productName;// set title of a popup in case the scheme is in the popup
var popup = scada.popupLocator.getPopup();
if (popup) {
popup.setModalTitle(window, document.title);
}// send notification about title change
renderContext.schemeEnv.viewHub.notify(scada.EventTypes.VIEW_TITLE_CHANGED, window, document.title);
};Hi
Mikhail, thank you for your kind comment, how about this popupLocator, it is under scada namespace, but I can’t find that define
All Guys
I meet some issues in schemerender.js file, it seems curCnlDataMap/imageMap are Map object, but I can’t find the inilization seems like imageMap=new map;
scada.scheme.RenderContext = function () {
this.curCnlDataMap = null;
this.editMode = false;
this.schemeEnv = null;
this.viewID = 0;
this.imageMap = null;
this.controlRight = true;
ipqiushengParticipantscada.scheme.UnknownComponentRenderer = function () {
scada.scheme.Renderer.call(this);
};scada.scheme.UnknownComponentRenderer.prototype = Object.create(scada.scheme.Renderer.prototype);
scada.scheme.UnknownComponentRenderer.constructor = scada.scheme.UnknownComponentRenderer;/********** Render Context **********/
// Render context type
this.viewID = 0;
};have find the defination in schemerender, mark here
will you prepare new models for Version 6? does that have some introduction about new versions? will that get some new interesting functions?
ipqiushengParticipanthttps://ibb.co/XLbhzSM
https://ibb.co/x8y0g0k
provide more image above
do you mean we install distributive on computer, then we can run the source code and debug our project?
I re-build wincontrol in my computer, that can fix most of issues about wincontrol. it seems the dll from Nu-get repository has some issues which will cause install locally failed, not sure other guys if meet same issues.
https://ibb.co/6RL98q9
just mark this for other learner, this because the wincontrol dll contain system.windows.forms v6.0.0, when project use this as a reference, it will show compile errors. I re-compile the whole wincontrol project, then use this as a reference, the conflicts of system.windows.forms v6.0.0 between v4.0.0 disappeared. thank you for your kind remind.
ipqiushengParticipantthis is the image
ipqiushengParticipanthttps://ibb.co/LkLXjqq this is image
