RapidScadaHan
ParticipantDear Mr.Mikhail,
I tried install a rapid gate on remote PC, but I can copy the module configuration files ModRapidGate.xml and ModRapidGate_Reg.xml into the edited project because I can not see them. Where these files ModRapidGate.xml and ModRapidGate_Reg.xml are located?
Thanks a lotRapidScadaHan
Thank you for your reply.
A separate instance should be created in the project.
That means: if there are 3 remote communicators I have to create 3 instances on main Server, is it correct?
Thanks a lot
Han HoangRapidScadaHan
I have been structed a problem in Automatic module. I don’t understand where is wrong, the Automatic module sends an email with wrong alert. For example, the automatic module will be send alert an with value > 100 mA when the Over Leakage Current is up > 100 mA but in my case it is unnormal. You can see it via screenshots bellowing:
https://ibb.co/cNxcNH1
The Triger parameters is bellowing
https://ibb.co/XC7QqB2
Where is wrong? How to fix it?
Thanks and best regards
ParticipantDear Vitorlam,
I have not been purchased any plugin. You have to do wall steps in instruction so that you can get results.
The best regards
I am not good at mqtt so could you create online a mqtt driver of my meter device. This device is working now. My boss agreed with me to charge fee for you. You can suggest a fee via my email: Hoanghan1962@yahoo.com
ParticipantDear greenfoxx and All
The device forwards data in Json format likes this:
ExampleJSON, for 1 meter being transmitted:
“rtdata”: [ {
“uid”: “00:01:02:03:04:05:00:01”,
“did”: 1,
“S1”: 278.59, //Phase1 Apparent Power (VA)
“S”: 837.36, //SystemApparent Power (VA)
“A1”: 0, //Angle1 (Degrees)
“V3”: 242.17, //Phase3 Voltage (V)
“P2”: 262.23, //Phase2 Power (W)
“RE3”: 2046057.995, //Phase 3 Reactive Energy (varh)
“Q3”: -95.057, //Phase3 Reactive Power (var)
“A2”: 0.15, //Angle2 (Degrees)
“E”: 53559.31592, //System Energy (Wh)
“U3”: 1.025, //Phase 3 Line to Line Voltage (V)
“P3”: 262.84, //Phase3 Power (W)
“REx”: 18592.91342, //System Reactive Energy Export(varh)
“U1”: 0.73807, //Phase 1 Line to Line Voltage (V)
“V1”: 241.3, //Phase1 Voltage (V)
“RE2”: 512121.6998, //Phase 2 Reactive Energy (varh)
“ts”: 1516362683, //Servertime (Seconds)
“Ex3”: 286326.6791, //Phase 3 Export Energy (Wh)
“AE2”: 541141.7201, //Phase 2 Apparent Energy (VAh)
“RE”: 2285337.066, //System Reactive Energy (varh)
“I2”: 2.423, //Phase2 Current (A)
“A3”: 0.13, //Angle3 (Degrees)
“E2”: 17881.0226, //Phase 2 Energy (Wh)
“REx1”: 352050.9531, //Phase 1 Reactive Energy Export(varh)
“I”: 7.2894, //SystemCurrent (A)
“In”: 6.5333, //Neutral Current (A)
“S3”: 279.52, //Phase3 Apparent Power (VA)
“U”: 0.7518, //System Line to Line Voltage(V)
“F”: 50.055, //Frequency(Hz)
“RE1”: 74246.0259, //Phase 1 Reactive Energy(varh)
“P1”: 263.19, //Phase1 Power (W)
“E1”: 110343.0785, //Phase 1 Energy(Wh)
“PF”: 0.94137, //SystemPower FactorNounit
“REx3”: 6239.513739, //Phase 3 Reactive Energy Export(varh)
“AE3”: 2085295.743, /Phase 3 Apparent Energy(VAh)
“V”: 241.72, //SystemVoltage(V)
“Ex”: 317545.1858, //System Export Energy(Wh)
“Q”: -282.33, //SystemReactive Power (var)
“S2”: 279.24, //Phase2 Apparent Power (VA)
“REx2”: 7412.039811, //Phase 2 Reactive Energy Export(varh)
“PF3”: 0.94495, //Phase3 Power Factor Nounit
“PF2”: 0.94336, //Phase2 Power FactorNounit
“E3”: 17169.13177, //Phase 3 Energy(Wh)
“I3”: 2.4304, //Phase3 Current(A)
“PF1”: 0.94843, //Phase1 Power FactorNounit
“P”: 788.26, //SystemPower (W)
“U2”: 0.49234, //Phase 2 Line to Line Voltage(V)
“V2”: 241.68, //Phase2 Voltage(V)
“Q2”: -95.957, //Phase2 Reactive Power (var)
“Q1”: -91.319, //Phase1 Reactive Power (var)
“AE1”: 461996.2103, //Phase 1 Apparent Energy(VAh)
“Ex2”: 85510.65138, //Phase 2 Export Energy(Wh)
“Ex1”: 37562.71023, //Phase 1 Export Energy(Wh)
“AE”: 3088475.549, //System Apparent Energy(VAh)
“I1”: 2.436 //Phase1 Current (A)
Thank you again.
ParticipantDear greenfoxx,
I have been rode many topic about MQTT that can help me to read data from my device, but I did not understand. I need your help now.
I have a device that can setup to forward data is in JSON. You can see a screenshot as bellowing.
https://ibb.co/0FnHphk
I used MQTT driver version 5.0 to read data with following configuration but not result.
https://ibb.co/jVmgx1z
https://ibb.co/Gph9WDX
https://ibb.co/2gJjc36
So I want to ask you:
– Which version of MQTT driver that can read data from this device?
– How to configure a MQTT communication line? (Note: the device has a IP 192.168.1.117)
Can we see the communication device on Linux Version? That means When configure a communication line on OS Windows we can see value on device. For example:
https://ibb.co/pyCF7XY
The best regards
Thank you for your reply. But I want to ask you somethings likes these:
– The PLC is brand new for me so How to install a Rapid Scada into Linux-based PLC?
– Can use some features of PLC for Rapid Scada? For example the Linux-based plc using will be the Pigeon RB700. It has many features: RS485 interface, I/O pins et.
– The Pigeon RB700 has a 8 GB (Up to 32GB) Flash memory. It will be very small storage for Server, is it correct?
Han Hoang -
