arvindh91
ParticipantThanks Mikhail,
ScadaCommSvc.exe ran in different USER
Then i changed to same user of CodeSys OPC .
after Change it and Restarting the System , PLC tags values recived correctly in SCADA COMM and OPC Quality Status : GoodThanks.
arvindh91
ParticipantHi Mikhail,
In Matrikon OPC client i am getting values of PLC tags through CoDeSys OPC
IN Matrikon OPC client OPC quality – Good , non specific.CoDeSys OPC and SCADA Comm both are running in same user account
for reference image see in below link.
This reply was modified 9 years, 5 months ago by
arvindh91.
arvindh91
I need to display the temperature form modbus in scada like graph and
i need log temperature data and want to retrieve like historianarvindh91
ParticipantThere is any way without OPC server to communicate with Ethernet/ip device
arvindh91
ParticipantThanks to All
arvindh91
ParticipantThanks mikhail.
arvindh91
ParticipantHi mikhail
finally solved
the device number and name mis-matchthanks for your support
arvindh91
channel numbers are not in the grid
I also clicked the button “Pass to SCADA-Server”
and restart the SCADA-sever and SCADA-commuicatr servies
but still channel numbers are not in the gridIn Device Data page value grid changes if change value in modbus RTU simulator
