How to enter sent value through web interface
Forum Home › Forums › Understanding the Software › How to enter sent value through web interface
  • #352
    arvindh91
    Hi
    I am beginner to rapid scada
    how to create textbox in web interface that is SCADA- Scheme . the value entered in the textbox should be transmitted to modbus and write in holding register or coil of particular address
    #353
    1. Create the appropriate output channel using SCADA-Administrator
    2. Open SCADA-Scheme Editor, create an element, choose “Send Command” action for the element and fill “Output channel” property of the element.
    When you click the element, a command window will appear.
    #358
    arvindh91
    Thanks mikhail.
