January 13, 2023 at 11:10 am in reply to: After several days of running continuously, the rapidSCADA session is denied #11950
grhsc
ParticipantDo the OPC servers show active connections? How many connections in total?
– At this time, I can no longer use the client software to know its CurrenSession.
That is to say, the server rejects all new sessions, but it is strange that the original rapidSCADA will also be rejected. But other existing sessions are still maintained.
Looking at the 1 minute archived data before it was rejected, the number of sessions was less than 5 (10 is the server maximum sessions ) I did not see the CurrenSession > 5 in the archived data, I can only guess that it was at 1 Minutes are rapidly greater than 10 and no records are archived because 1 minute intervals.What does Rapid SCADA 6 do if an OPC connection is closed by OPC server?
– When the rapidSCADA session is terminated, the data cannot be updated, this is the wrong log2023-01-13 18:17:37 Delay before connecting 4.6 sec
2023-01-13 18:17:42 Connect to opc.tcp://192.168.204.100:49320
2023-01-13 18:17:42 Error connecting OPC server:
System.AggregateException: One or more errors occurred. (BadSecureChannelClosed)
—> Opc.Ua.ServiceResultException: BadSecureChannelClosed
at Opc.Ua.Bindings.ChannelAsyncOperation`1.End(Int32 timeout, Boolean throwOnError)
at Opc.Ua.Bindings.UaSCUaBinaryClientChannel.EndSendRequest(IAsyncResult result)
at Opc.Ua.DiscoveryClient.GetEndpoints(RequestHeader requestHeader, String endpointUrl, StringCollection localeIds, StringCollection profileUris, EndpointDescriptionCollection& endpoints)
at Opc.Ua.DiscoveryClient.GetEndpoints(StringCollection profileUris)
at Scada.Comm.Drivers.DrvOpcUa.OpcClientHelperBase.SelectEndpoint()
at Scada.Comm.Drivers.DrvOpcUa.OpcClientHelperBase.ConnectAsync()
at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
at Scada.Comm.Drivers.DrvOpcUa.Logic.OpcClientHelper.Connect()grhsc
ParticipantGreat, thanks a lot!
grhsc
Participantsorry, I want to say here is that when the project is uploaded, it keeps stopping.
It’s been 2 minutes and it still won’t start the Webstation
2022-11-18 16:45:49 [SCADA6][SCADA6$][ACT] The configuration database has been received successfully
2022-11-18 16:45:49 [SCADA6][SCADA6$][INF] The application is ready for operating
2022-11-18 16:46:18 [SCADA6][SCADA6$][ACT] Webstation is stopped
——————————————————————————–It’s been 2 minutes and it still won’t start the Webstation. 16:46:18
Webstation can only be started if the page is manually refreshed. 16:48:13
Is it possible to add automatic start of Webstation after the upload? Instead of refreshing it manually after each update, obviously manual refreshing is not user-friendly
2022-11-18 16:48:13 [SCADA6][SCADA6$][ACT] Webstation 6.0.0.0 started
2022-11-18 16:48:13 [SCADA6][SCADA6$][ACT] Storage FileStorage 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\FileStorage.dllgrhsc
ParticipantHello Mikhail
I believe the reason for my error message is exactly what your analysis turned out to be.
But there is a difference, it is not 10s, but a long time, I have observed many times.
If I don’t refresh the page, it will always have this error message, until I refresh the page again, I can see Webstation 6.0.0.0 started from the log.It doesn’t seem very friendly, if I always need to manually refresh once after uploading.
Is my case a special case?
From the log below you can see
From 2022-11-18 16:48:13 I manually re-refreshed the page, Webstation started to start—————————
2022-11-18 16:45:44 [SCADA6][SCADA6$][ACT] Plugin PlgWebPage 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgWebPage.dll
2022-11-18 16:45:44 [SCADA6][SCADA6$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
2022-11-18 16:45:44 [SCADA6][SCADA6$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
2022-11-18 16:45:44 [SCADA6][SCADA6$][ACT] Receive the configuration database
2022-11-18 16:48:13 [SCADA6][SCADA6$][ACT] Plugin PlgChart 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgChart.dll
2022-11-18 16:48:13 [SCADA6][SCADA6$][ACT] Plugin PlgMain 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMain.dll
2022-11-18 16:48:13 [SCADA6][SCADA6$][ACT] Plugin PlgScheme 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgScheme.dll
2022-11-18 16:48:13 [SCADA6][SCADA6$][ACT] Plugin PlgSchBasicComp 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgSchBasicComp.dll
2022-11-18 16:48:13 [SCADA6][SCADA6$][ACT] Plugin PlgWebPage 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgWebPage.dll
2022-11-18 16:48:13 [SCADA6][SCADA6$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
2022-11-18 16:48:13 [SCADA6][SCADA6$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
2022-11-18 16:48:13 [SCADA6][SCADA6$][ACT] Receive the configuration database
2022-11-18 16:48:18 [SCADA6][SCADA6$][ACT] The configuration database has been received successfully
2022-11-18 16:48:18 [SCADA6][SCADA6$][INF] The application is ready for operatinggrhsc
ParticipantI tried to include pictures but failed, so please click the link to see pictures, thanks
https://drive.google.com/file/d/1tKqB4epVIkIoed-pDh4uKBsP7RAgbTR2/view?usp=share_link
grhsc
Participantthank you very much!
Looking forward to seeing the project converter soongrhsc
ParticipantThank you very much, by customizing different xml I have got what I want.
But the font is really blurry, I tried adjusting to 14, still the samegrhsc
Participantthank you,
Sorry I may not have described clearly, it is not chart pro, but chart in Extra Scheme Components.
Also, I found that the chart pro Components seems unclear, a little vague, is it the reason for the size and settings?
2 type chart questions, sorry for confusing you
as below
https://drive.google.com/file/d/18vgheBRPArofqCLjEb__N632x1_mWJjt/view?usp=sharing-
This reply was modified 4 years, 10 months ago by
grhsc.
January 12, 2022 at 10:37 am in reply to: After the custom unit is wrong, it cannot be modified #9896grhsc
ParticipantMaybe I misunderstood name and sign, I did it again and it seems to be normal.
The sign field is the unit displayed in the scheme, right?thank you
