grhsc
Viewing 15 posts - 46 through 60 (of 69 total)
  • in reply to: SCADA-related services cannot be automatic started #12093
    grhsc
    hello, this is the information returned
    C:\Users\rapid_scada>dotnet –info
    global.json file:
    Not found
    Host:
    Version: 6.0.12
    Architecture: x64
    Commit: 02e45a41b7
    .NET SDKs installed:
    No SDKs were found.
    .NET runtimes installed:
    Microsoft.AspNetCore.App 6.0.12 [C:\Program Files\dotnet\shared\Microsoft.AspNetCore.App]
    Microsoft.NETCore.App 6.0.12 [C:\Program Files\dotnet\shared\Microsoft.NETCore.App]
    Microsoft.WindowsDesktop.App 6.0.12 [C:\Program Files\dotnet\shared\Microsoft.WindowsDesktop.App]
    Download .NET:
    https://aka.ms/dotnet-download
    Learn about .NET Runtimes and SDKs:
    https://aka.ms/dotnet/runtimes-sdk-info
    in reply to: SCADA-related services cannot be automatic started #12090
    grhsc
    I’m not quite sure what these 2 applications refer to
    Webstation – does it mean the web UI of rapid scada v6? it won’t work, it shows an error on the login page: the application not ready, try again later
    administrator – does it mean the ScadaAdmin editor? I don’t know because the server doesn’t have this dev tools installed
    Please let me know if my understanding is incorrect
    By the way, the version I’m talking about is V6.01,thank you!
    • This reply was modified 3 years, 9 months ago by grhsc.
    in reply to: ArchiveDATCopy #12042
    grhsc
    great, thank you so much!
    in reply to: Zoom icons in Chartpro plug-in #12036
    grhsc
    Of course it is here.
    https://drive.google.com/file/d/1kOhrlu7_1u_FO8jMTyqLLhW2U6hPgWXZ/view?usp=share_link
    In the default white theme, it’s striking, but in the dark theme, it’s not easily visible, thank you
    in reply to: V6 – Extra Scheme Components #11995
    grhsc
    it’s working fine, thank you.
    in reply to: V6 – Extra Scheme Components #11994
    grhsc
    My pleasure!
    in reply to: V6 – Extra Scheme Components #11989
    grhsc
    here is log
    Components are loaded from the file C:\Program Files\SCADA\ScadaSchemeEditor\Web\bin\PlgSchBasicComp.dll
    2023-01-19 08:59:12 <WIN10SCADAV6><win10-vm><ERR> Unable to get the plugin type Scada.Web.Plugins.PlgSchExtraCompSpec from the assembly C:\Program Files\SCADA\ScadaSchemeEditor\Web\bin\PlgSchExtraComp.dll:
    can’t from program set “PlgSchExtraComp, Version=6.0.0.0, Culture=neutral, PublicKeyToken=null” load “Scada.Web.Plugins.PlgSchExtraCompSpec”。
    PlgSchExtraComp.dll is unlocking
    • This reply was modified 3 years, 10 months ago by grhsc.
    in reply to: V6 – Extra Scheme Components #11988
    grhsc
    Sorry I have to bother you again with this question
    I successfully updated to 6.01 and installed Extra Scheme Components without any errors, and I applied for a temporary key, it seems to have no problems,
    accroding 5.8 experience, it should be copied to the specified folder, after registration, it will appear in the Scheme editor. However, I don’t see the expected Extra Components.
    I did it again, including applying for the key, but I still can’t see the Extra Components.
    What is wrong? could yuu help me?
    in reply to: V6 – Extra Scheme Components #11986
    grhsc
    ok, thank you
    in reply to: V6 – Extra Scheme Components #11980
    grhsc
    hello
    I saw that the Extra Scheme Components V6 version has been released, I followed the manual to install (copy under the scada folder) but when I activate here
    Instance -> Webstation->Plugins
    it has an error
    Error creating plugin interface PlgSchExtraComp of type Scada.Web.Plugins.PlgSchExtraComp.View.PlgSchExtraCompView from file C:\Program Files\SCADA\ScadaAdmin\Lib\PlgSchExtraComp.View.dll: Could not load file or assembly ‘ScadaWebCommon.Subset, Version =6.0.0.1, Culture=neutral, PublicKeyToken=null’. The system cannot find the file specified.
    https://drive.google.com/file/d/1B-OkuOS5TRz_U_AJ_VIMZOPBq5_mSt3g/view?usp=share_link
    in reply to: The login page of the web always prompts an error #11974
    grhsc
    I changed 3 parameters:
    Ceneral->Start Mode: AlwaysRunning
    Process Model -> idle T/ime-out(minutes): 0
    Recycling -> Regular Time Interval:0
    in reply to: The login page of the web always prompts an error #11964
    grhsc
    Yes, when set up according to your method, it works perfectly, thank you very much
    in reply to: V6 – Extra Scheme Components #11963
    grhsc
    Can you estimate the release date of the Extra Scheme Components 6 version, it is really useful
    in reply to: The login page of the web always prompts an error #11952
    grhsc
    Sorry to bring this up again because it’s a little different.
    This error message still appears when RapidSCADA is running, not after re-uploading the project. According to the logs, if no one is using it (this is my guess, because it’s just my personal test) Webstation is stopped after 30 minutes
    It’s like a PC that goes into sleep mode over time if no one is using it. why?
    2023-01-13 15:03:45 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Webstation 6.0.0.0 started
    2023-01-13 15:03:45 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Storage FileStorage 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\FileStorage.dll
    2023-01-13 15:03:45 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgChart 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgChart.dll
    2023-01-13 15:03:45 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgMain 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMain.dll
    2023-01-13 15:03:46 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgScheme 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgScheme.dll
    2023-01-13 15:03:46 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgSchBasicComp 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgSchBasicComp.dll
    2023-01-13 15:03:46 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgWebPage 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgWebPage.dll
    2023-01-13 15:03:46 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
    2023-01-13 15:03:46 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
    2023-01-13 15:03:46 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Receive the configuration database
    2023-01-13 15:03:51 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] The configuration database has been received successfully
    2023-01-13 15:03:51 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][INF] The application is ready for operating
    2023-01-13 15:19:49 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] User admin is logged out, IP 192.168.31.139
    2023-01-13 15:40:44 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Webstation is stopped
    2023-01-13 18:07:18 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Webstation 6.0.0.0 started
    2023-01-13 18:07:18 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Storage FileStorage 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\FileStorage.dll
    2023-01-13 18:07:19 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgChart 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgChart.dll
    2023-01-13 18:07:19 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgMain 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgMain.dll
    2023-01-13 18:07:19 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgScheme 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgScheme.dll
    2023-01-13 18:07:19 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgSchBasicComp 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgSchBasicComp.dll
    2023-01-13 18:07:19 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgWebPage 6.0.0.0 loaded from file C:\Program Files\SCADA\ScadaWeb\PlgWebPage.dll
    2023-01-13 18:07:19 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
    2023-01-13 18:07:19 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
    2023-01-13 18:07:19 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Receive the configuration database
    2023-01-13 18:07:24 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] The configuration database has been received successfully
    2023-01-13 18:07:24 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][INF] The application is ready for operating
    2023-01-13 18:37:17 [DESKTOP-OAT2BS9][DESKTOP-OAT2BS9$][ACT] Webstation is stopped
    grhsc
    This is a low-speed (10 Sec) updated ua server, Could modifying some RapidSCADA comm parameters help reduce the chances of it being rejected?
